My first Activa
Skull
(Donor 2026)
x 382
Re: My first Activa
Unread post by Skull »
Received update today:
NO FAULT FOUND £68.40 PAID :?
So will have to have another think .....
Gary
Michel
Re: My first Activa
Unread post by Michel »
Is it not possible, like I did with a V6 Xantia, to source an unlocked known good ECU and try that?
Skull
(Donor 2026)
x 382
Re: My first Activa
Michel There’s little point trying that option now that my ECU has been checked but there also seems a lack of cheap spare parts specifically for the Activa.
I’m probably going to look at Llamba sensor next but I would have thought I’d have had a confident report from either of the garages that it’s been to and also I would have thought a dash warning light / eml on indication.
Mrs is starting to question my sanity :roll:
Gary
x 3298
Re: My first Activa
I think it is fair to say that everybody who has/runs a Citroen has a certain lack of sanity!
Skull
(Donor 2026)
x 382
Re: My first Activa
:roll: :roll:
Gary
x 2004
Re: My first Activa
Unread post by Stickyfinger »
dribble
Skull
(Donor 2026)
x 382
Re: My first Activa
Skull wrote: 13 Feb 2019, 13:36 13 Feb 19 fully fitted
Had to re-do it properly as gravity beat the previous effort. (www.woolies-trim.co.uk 285-GRY-D)
25 Jan 20
Skull - new headlining Jan 2020
Gary
Skull
(Donor 2026)
x 382
Re: My first Activa
CitroJim wrote: 03 Dec 2018, 16:48 Skull... NEVER, EVER trust the timing hole in the crank pulley on an Activa!!! They are NOT accurate on a used pulley...
Being a dual-mass the outer annulus - where the timing hole is - moves relative to the inner annulus over time...
I used to have a solid pulley from a Pug 205 I used for timing purposes...
Well after finally relenting I have bought a solid pulley (couldn't find one anywhere and also appealed on other sites).
The difference between the two is about 25 degrees and comparing the two, looks to have been running too advanced.
Old and New
Old and New
Pulley slipped approx 25 degrees
Hoping to get it all back together tomorrow and see how the engine sounds ...
I'm guessing I've been lucky not to damage the engine and hoping to get my boost back .....
Gary
Skull
(Donor 2026)
x 382
Re: My first Activa
Door would only lock intermittently, the door had been damaged at some stage of it's life before I got it.
I had thought it was due to poor re-assembly as a few fasteners were missing but even with the lock removed it required assistance before the lock would operate either way. Once removed a squirt of WD40 immediately restored it so something internal must have been seising up. Re-fitted with proper fixings, taped loom where exposed and spare 2nd hand membrane - all working.
The attachment DSCF0001.JPG is no longer available
Skull's Sticky door lock previous
Skull's Sticky door lock trace of needles where it's been pulled out,  lock and window loom poorly routed/fitted
Skull's New membrane and missing/broken fixings replaced
EDIT After doing this job and examining the difference between XI (photos below) and my X2 (more metal components in latch mechanism) a quick fix might have been possible by removing the one upper and inner screw and operating the external handle which opens an internal aperture allowing you to squirt lubricating fluid into the majority of the components. In my case I wanted to see the previous repair that had been carried out anyway and improve the fixings/membrane.
Skull's fully re-assembled and working
Skull’s lock aperture
Skull’s lock 20mm depth to mechanism
Gary
x 1746
Re: My first Activa
How did the engine run after getting the pulley/timing sorted?
Skull
(Donor 2026)
x 382
Re: My first Activa
It hasn't had a road run yet as MoT expired/travel restrictions now in force but ..... it is sounding better and a bit more boost can be felt on intake hose so fingers are crossed.
Thinking about getting the MoT sorted so she's ready to go ........
Gary
x 1746
Re: My first Activa
Sounding promising... :)
Skull
(Donor 2026)
x 382
Re: My first Activa
Skull’s MoT
Skull’s MoT
Now I need some grippier tyres - a short drive back from the MoT has highlighted that the turbo is working (gauge read 9 PSI) =D> but the Uniroyal RainExperts 3 are not up to the Activa requirements 8-[
Gary
admiral51
(Donor 2026)
x 392
Re: My first Activa
Unread post by admiral51 »
Congrats Skull =D> =D> =D>
x 2004
Re: My first Activa
Michelin's, David H & Robert BL Autos recommend them, if you keep standard wheels, Toyo Proxies T1R (the NEW ones only, not the older Tr1's) if you go 16 0r 17 inch wheels.
