C5 Eolys Question.
x 7169
Re: C5 Eolys Question.
Peter.N. wrote: 12 Aug 2019, 09:58 Should I really have bought this car :? :o :shock: 8-[
GiveMeABreak wrote: 19 Sep 2018, 23:14 it is not physically measured. You will need to rest the counter when you top it up using Diagbox.
I find this "you have to tell the car you have topped up the fluid" a bit unbelievable. What next...you need to tell the car you have put more petrol in/topped up the coolant or put air in your tyres.
Did the manufacturers forget on purpose to do a little bit of "programming"/sensor installation to make this as easy as filling up your fuel tank.
x 6950
If you don’t reset the additive counter, the system will not know you have filled the additive tank (as it is not physically measured) and at sometime soon after the warning, it will go into reduced engine power mode as it will not operate the additive pump and will not regenerate, leading to a blocked particle filter.
To be honest Peter, if you don’t want the faff of crawling under, filling th tank and resetting it, just get the dealer to do it. They’ll probably do it for just over £200, and you won’t have to worry about it again for another 75-80k miles at which time the particle filter will need cleaning or replacing by then.
x 6950
NewcastleFalcon wrote: 12 Aug 2019, 10:19
On the earlier models, they did have a separate additive ECU, and these did have a measuring function. There was a float measuring system in the additive tank. However because of ongoing problems they soon disabled the measuring function from the additive ECU.
Because they had so many problems with having to replace the actual additive ECU, they’ve now done away with that altogether and transferred the function to the engine management ECU. I guess they think they can perform the same function with less additionality. At the end of the day you really only need to perform this operation once or twice over the life of the vehicle.
Harlequin
x 24
Unread post by Harlequin »
i had a mk 1 2.2 HDi with DPF, and the ECU in teh OS sill. There was no float in the tank.
x 1240
Unread post by Peter.N. »
I think I will need a code reader of some sort. I have two Lexias but neither work, is the old lexia equiped to deal with the X7?
x 6950
Harlequin wrote: 12 Aug 2019, 13:52 i had a mk 1 2.2 HDi with DPF, and the ECU in teh OS sill. There was no float in the tank.
Actually there is a level sensor in the additive tank on your 2.2 (C5 MK I DW12TED4) Simon. I'm not in the habit of making it up, but it may not be what you might suspect of an arm and float, but there is a sensor there. :wink:
The tanks additive tanks were still shipped with the hardware in, but the measuring function was disabled and removed from the additive ECU software. It is just not used as I said previously.
If it's necessary to prove it - item 40 on the Diagram:
Click Diagram to Zoom
RefDesignationRefDesignation
1Additional heater control relay39Additive tank
2additional heating (electrical resistors (2a) or heater (2b)) (*)40Low additive level sensor
3Variable geometry turbocharger41Additive injection pump
4Air flow meter Air temperature sensor42Fuel tank
5Air cleaner43Additive injector
6catalytic converter44Booster pump (low pressure)
7Particle filter45Electric fuel heater
8Exhaust gas temperature sensor (downstream of the catalytic converter)46engine coolant temperature sensor
9Differential pressure sensor47Plug (overflow)
10Exhaust gas temperature sensor (upstream of the catalytic converter)48Safety valve
11Turbocharging pressure regulation solenoid valve49Fuel tank cap presence sensor (*)
12Recycling regulation electrovalve (EGR)50Centralised diagnostic socket
13Finned diffuser piston control pneumatic capsule51Battery
14Exhaust gas recycling valve (EGR)52Injection double relay (engine relay unit)
15Water-to-air heat exchanger (inlet air heating)53Vehicle speed sensor
16Exhaust gas/water exchanger (EGR)54Accelerator pedal position sensor
17Inlet air heater throttle control electrovalve55Clutch pedal switch
18atmospheric pressure sensor (integrated in the injection ECU)56Brake pedal switch
19injection ECU57Pre-post heat box
20Heated rear screen58Fuel cooler
21Stability control ECU (*)59Fuel filter
22Automatic gearbox ECU (*)60Engine speed sensor
23Trip computer (*)61Camshaft position sensor
24Electronic tachometer62Pre-heater plugs
25Service LED63Fuel high pressure common injection rail
26Pre-heating warning light64High pressure fuel sensor
27Diagnostic warning lamp65Fuel temperature sensor
28Fuel level indicator66High pressure fuel regulator
29Fan67high pressure fuel pump
30air conditioning compressor683rd piston deactivator on the high pressure fuel pump
31Engine coolant temperature warning light69Diesel injectors
32Engine coolant temperature gauge70"Swirl" control electrovalve
33Built-in systems interface71"Swirl" control diaphragm
34Cruise control switch72Inlet air heater throttle
35Cruise control safety contact73Throttle butterfly housing (EGR)
36Cruise control switch74air/air heat exchanger
37Switch module (at the steering wheel)75Throttle housing control electrovalve (EGR)
38Fuel additive ECU76Inlet manifold pressure sensor
Harlequin
x 24
And yet when my own car had the eolys tank replaced it was simply that - a tank, with nothing in it. The additive injection pump is located next to the fuel tank pump
x 6950
The injector pump (43) is in the fuel tank (42) but the additive injection pump (41) is inside the additive tank. The level sensor is probably incorporated into that.
x 3565
Peter.N. wrote: 12 Aug 2019, 16:29 I think I will need a code reader of some sort. I have two Lexias but neither work, is the old lexia equiped to deal with the X7?
Depends on what you mean by 'old Lexia' ? Mine dates from (at a guess) 2013-ish. I got it from EasyDiagnostics and it works well. I've updated it successfully to a decent and stable version (x.57 ????). The OBD port for the X7 is located in the base of the centre armrest. You open the lid and pull up the rubber mat on the bottom.
x 1240
One I have had for 10 years or more but I bought another probably 3 or 4 years ago. I will try and get one hooked up and se if at least it displays the X7 on the list. What do I have to enter to get it to connect?
moizeau
x 423
Unread post by moizeau »
Is there anyone close to you that can swap interfaces, 'puters, try yours with theirs etc?
Pete
x 6950
If it's older than 10 years is will likely be an older Revision 'B' interface and you will need a CAN version for the X7 or it wither won't recognise some or all of the ECUs. This all depends on what hardware is inside the VCI of course. These clones are not all made equal, but no harm in trying.
admiral51
(Donor 2026)
x 392
Unread post by admiral51 »
Ah well that is a question that only you can answer, but maybe it is a question you have asked yourself before :lol:
If you can get your head around the complexities of XM hydraulics and wiring then the C5 X7 will be a walk in the park for you, trouble is now you have to talk to the car first to find out what it says is wrong with it before you then talk to the uninterested parts person who has no idea what is wrong and has no intention of believing what you say is wrong even though you know what you need to sort the issue out :roll:
So the only real difference is now when you talk to the car it actually talks back, you just need to a computer to talk to it and understand the reply :)
admiral51
(Donor 2026)
x 392
I hate to burst the bubble but for a good few years a certain German HGV manufacturer has had a BSI system where by that it tells you the brake pads are low, you can replace them yourself and the BSI will acknowledge the new pads thickness,the dash will show new pad thickness, but you will need a dealership machine ( Lexia as example) to tell the BSI that they have been changed to remove the low brake pad warning lamp. It can even pass a full manual MOT brake test,no issue with braking pressures etc but will fail as a warning is showing on the dash :(
Yes they did forget on purpose :evil:
x 7169
Its the same when I read about the "battery disconnect dance". How much extra "programming" would be required to simply invoke a "safely remove hardware" procedure by clicking on an option "safely disconnect battery", or even old school pressing a button which performs the dance for you without you having to remember the steps!
Silly me...its always payday for the Dealer Service Centres when the poor punter screws something up by forgetting a step and the windows dont work any more, or worse still the car wont start!
