Hi guys.
So, i'm sat scratching my head. I have had the eml on, comes and goes and i've pulled two codes - as above p2173 and 1499 for something called an air mixer.
Now, i've done some small reading and think this item is the same as the air doser from the euro 4 psa 1.6 engine, the butterfly valve in the intercooler system. But can anyone 100% clarify? as air mixer to me could mean EGR? that would mix the exhaust gas with inlet rather than just be a motorised butterfly valve.
On top of this, this morning the tpms came on, no tyres are been monitered now, saying the back two tyres are under inflated (all ok on pressure)
i'm a tad puzzled by the total lack of tpms! no communication via my scan tool as well.
Please, if anyone can jump start me in the right direction i will owe you a pepsi.
Dave
Partner 2015 'Air mixer' P2173 and p1499 AND TPMS gone down the pan!
Kerek85
- x 6962
Re: Partner 2015 'Air mixer' P2173 and p1499 AND TPMS gone down the pan!
The golden rule... we need the VIN
Kerek85
Vin is VF3**************[VIN obfuscated, can be read by forum staff].
I have just realised its a Peugeot partner, not berlingo.
Uncertain if the number in the middle of the vin is a 0 or an O
thx
- x 6962
That's correct as you have written it, so I'll move this to the Peugeot Section
PARTNER TEPEE (B9) FAMILY SALOON 1.6 HDI 115 (DV6C) Manual gearbox 5
Leave it with me for a second
- x 6962
Ok, so here you go and yes the Air Mixer is the same as the Air Doser - number (8) in the diagram, also referred to in the fault tables as Air Metering Valve.
Ok, so here are your fault codes as they relate to your engine:
| Fault code | P2173 |
| After sales description of the fault code | Air metering valve: Position incorrect (too open) |
| Description of the diagnostics | The position measured is greater than the reference by more than 100 % for 5 seconds |
| Conditions of activation of the diagnostics | Engine running |
| Conditions of disappearance of the fault | Driving for 5 minutes |
| Down-grade modes if fault present | - |
| Switching on of the warning lamp and/or warning message | Warning lamp MIL |
| Main customer complaints likely | Engine stop downgraded |
| Suspect areas | Air metering valve Electrical harness Connectors |
| Fault code | P1499 |
| After sales description of the fault code | Air metering valve : Position incorrect (too open) (Service) |
| Switching on of the warning lamp and/or warning message | - |
| Main customer complaints likely | Noise Smoke from the exhaust Slightly higher fuel consumption Jerking/stalling Lack of power No automatic stopping of the internal combustion engine |
Kerek85
Thank you muchly!
In essence, if number 8 is all ok and operational its down to the wiring loom or connectors!
Would your look up have the knowledge if this vehicle runs off tpm in the rim valves or does it use another method for the tpms?
- x 6962
Your Partner has Tyre Pressure Monitoring Valves and a receiver unit.
Kerek85
Thanks marc.
Will help me to go down the right road. Shall let you know how i fair.
Dave.
Dave.
- x 6962
Ok good luck
Wiggs
Hi was the issue down to number 8 in the picture air mixer?
I have the same fault code's on my DS3.
