Hello,
I have a Citroen C5 2.0 HPi exclusive fitted with xenon and the left lamp changed the color to pink so I guess the lamp is dying.
Replacing xenon lamps is expensive, so I am thinking in change for a regular lamps.
Is that possible? Will the normal lamps fit?
Thank you
Citroen C5 I - Xenon Headlight Question
- x 6955
Re: Citroen C5 I - Xenon Headlight Question
No Fabio.
They must be the correct Xenon bulbs as they have a completely different fitting and electrical requirement. You should also replace these in pairs. The xenons last a lot longer than conventional bulbs, so don't be tight and get the proper ones.
Fabio
- x 6955
If you want the correct type of bulbs, post your VIN here and I'll let you know.
Fabio
Thanks for your help
- x 6955
Ok, so you have 2 main bulbs for the headlights - one is the Xenon (11 on the diagram) which is a D2R bulb and the other is an H1 55W bulb (number 10).
A word of caution - I strongly suggest you avoid ebay and Amazon for these D2R bulbs - as it's estimated that a very high proportion are fakes and will not be originals!
I recommend OSRAM - and get them from an approved reseller or authorised reseller to avoid Chinese copies that are not of the same quality and will not last as long.
Fabio
Thank you very much
