Rear height adjuster arm nipple/ball worn out.
OlemTheGolem
x 5
Unread post by OlemTheGolem »
Hi again! Last week I was doing a little citrobics session when I heard a noise from the rear and the rear locked up. After inspection the white plastic arm popped off the corrector, just popped it back on. It kept falling off so I bought a replacement. However it turns out it's the nipple/ball on the adjuster itself that is worn out, is this a replaceable part or do I have to replace the entire unit?
Is this called a nipple or a ball? English is not my first language. :roll:
Looking at photos the arm does not seem replaceable, but I haven't been able to check my own since it's covered in rust inhibiting oil that's quite thick.
electronmirror
x 30
Re: Rear height adjuster arm nipple/ball worn out.
Unread post by electronmirror »
Hi,
I had exactly the same problem on my Xantia estate. It is possible to replace the ball headed threaded stud. The original stud is only peened into the arm, not even welded. Once replaced the white plastic arm (often referred to as 'the dog bone') will not jump off.
I bought several in anticipation of having to replace the front and rear studs on the height corrector, they are less than £1 each. Here's a link to the supplier I got mine from.
https://www.sgs-engineering.com/gas-str ... -extension
The ball head is 8mm diameter and thread is M5. It's a little bit fiddly to do on the rear but the frame of the height corrector can be removed without disturbing the hydraulic pipes. The front is more difficult.
If you get stuck sourcing these send me a pm and I'll post you a couple.
Happy spannering :)
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,980miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
OlemTheGolem
x 5
Cheers! Thanks alot for the answer and link. I'll probablly be able to source some locally :-D
Sloppysod
x 396
Unread post by Sloppysod »
Not sure how big there are but I see some with 10mm diameter balls on Ebay when searching for a "Gas strut Ball" recently - any good?
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
Skull
(Donor 2026)
x 381
Unread post by Skull »
It is also possible to temporarily fit plastic ties (or wire) in a figure of eight loosely around the arm and dog bone so preventing it from popping off but still allowing the joint/arm to rotate as required ....
Gary
OlemTheGolem
x 5
Skull wrote: 08 Aug 2019, 15:34 It is also possible to temporarily fit plastic ties (or wire) in a figure of eight loosely around the arm and dog bone so preventing it from popping off but still allowing the joint/arm to rotate as required ....
This is indeed what i did for now, did a ~600 mile round trip this weekend with it zip tied on there. will remain like that at least until Thursday or whenever the new ball heads arrive and i have a day off :)
