Hi,
I'm after some advice please. I'm trying to remove the metal camshaft cover from my 16v hdi and it won't budge.
As far as I can see there are no missed bolts. It's the cover that the studs that hold the injectors screw into.
I've been told that there's a gasket type sealent used on them.
How easily should it lift off? I don't want to force it too much and risk damage.
Engine is in the vehicle so a hammer and drift is not really viable if they are a bit of a pig to remove.
I need to have the head off as the cam belt stripped teeth at speed.
Also a second question. The chain between the two camshafts doesn't seem to have any visible different coloured links to do the timing that I can see. The timing is all out. Any advice? Are there marks on the sprockets when I do get it apart?
Thanks in advance.
2.0 hdi diesel camshaft cover removal
- x 1484
Re: 2.0 hdi diesel camshaft cover removal
Nothing special listed...
Timing - there should be 2 black marks on the chain, but if the drawing is right it's just 6 links between the marks on the cams.
Tightening sequence for cam carrier
KeithJ
Thank you very much for that. Most helpful.
I'll just persevere. It really doesn't seem to want to come off.
