Can someone help with a part number for outer cv joint?
The entire drive shaft is too expensive from citroen
Thank you
C5 x7 cv joint automatic gearbox
- x 6954
Re: C5 x7 cv joint automatic gearbox
Here you go:
Item (1) Left, New, part 3272RZ, £520.21
Exchange, part 3272SA, £448.98
Item (2) Right, New, part 3273SN, £482.27
Exchange, part 3273SP, £463.56
These are Citroen prices inc. VAT and each has an additional refundable surcharge of £66.96 on top of these prices.
So for non dealer new parts, focus on part number 3272RZ or 3273SN depending on left or right in your search.
- x 1919
The OP was asking for the outer CV joint, Marc. It doesn't seem available on the drawing you've posted, just the boot kit.
- x 1919
Have you considered a second hand item?
- x 3295
You probably cannot (from Citroen, at least) buy the CV joint; it looks like they only do the whole drive shaft.
Cristidica
Thabk you but i only need the cv joint on right side i'm assuming is the same for outer ones either left or right
I wont find on citroen service box
I bought the new drive shaft from j&r ltd in uk, after 2 days started clicking the same as before and it vibrates at 20-30 miles and cracking when steering , worse then the old one only Good thing about it , is the boot gaiter is not ripped
So what i wanna do is change on the old oem drive shaft the outer cv joint
Any link with only the cv joints?
- x 6954
They’re not available separately from Citroen Paul, hence the expense, as they are complete shafts.Paul-R wrote: 01 Aug 2019, 15:44 The OP was asking for the outer CV joint, Marc. It doesn't seem available on the drawing you've posted, just the boot kit.
I’ve done a post on it here:
viewtopic.php?f=3&t=61695&start=15#p597817
- x 1919
Yes, I strongly suspected that.
There is another possible solution. Years ago on my Mk1 C5 I needed to change the outer CV joint and I was able to take it off a drive shaft which was for another gearbox. It would probably mean going down the second hand route again, to keep costs in check, but is another option.
- x 5648
My GS used to gobble up CV joints like they were going out of fashion and the only option was a full driveshaft. £180 in 1985!
I haven't had to do one since that became bean tins.
Daughter's 104 needed one. £35 for the full shaft
- x 6954
Ditto that Steve, both my 1000 cc 1976 and my 1979 GS 1220 ate CV joints for breakfast. I had them done every year as it always failed the MOT on the same flipping thing.
Cristidica
I bought the whole driveshaft from https://www.jandrcvjoints.co.uk/citroen ... haft/DS943
Lasted 2 days
Lasted 2 days
Cristidica
So i'm assuming its something to do with the length
I measured the old oem drive shaft and is 989-990 mm something like that, i' ve seen they have some drive shaft with 957 mm length for automatic gearbox
I dont understand
Someone who can give me a link with a driveshaft that is not 400+ pounds?
Thank you
I dont understand
Thank you
- x 6954
Just search on Google ‘citroen 3273SN’ for example and you’ll find options that are cheaper.
Don’t try and search parts suppliers directly as you’ll be searching forever.
