Hi,
I have purchased a 2016 Dispatch Enterprise (2015 model) the van did not come with a sat nav unit. I purchased a replacement Teletrac which works with the exception it will not work a route,
I have reset it a few times and still no joy, any ideas on how to fix this. Would at other unit work with the installed wiring.
Teletrac Sat nav in a Dispatch van issue
- x 6954
Re: Teletrac Sat nav in a Dispatch van issue
Those systems were an integrated solution comprising of a SmartNav, stolen vehicle tracking and fleet management messaging and routing - so I doubt whether it will simply work without the rest of the integrated system being configured.
I think it would be simpler and easier to get a standalone Sat Nav system and be done with it.
If you post your VIN up I can see what kit you do have as standard and whether there is anything else needed.
Mrkdavis21
Thanks Marc for the information, much appreciated. The VIN is VF7**************[VIN obfuscated, can be read by forum staff], would a aftermarket sat nav which uses a mini usb, Be powered by the usb cable already there?
- x 6954
Ok, so no on the USB front - as that is really designed for connecting an MP3 player to play music via the audio system, It's not designed for charging or powering equipment - you'll need to use the 12V accessories / cigarette lighter socket for powering devices.
You have the RD45 Audio system, which is already Bluetooth compatible for telephone and for Audio streaming and will play MP3 CDs, as well as MP3 files via the USB as already mentioned.
I would return the telematic unit as it won't operate properly.
So for your aftermarket sat nav, - it should come with a 12V cigar lighter adapter to power it, or you can hard wire it using a piggy back fuse which will save splicing any wires.
Mrkdavis21
Thanks Marc, I was hoping to be able to use the existing cable for the now defunct Telematic unit (will return). Will buy an aftermarket sat nav. and hardwire it.
Again thanks for your help.
Mark
Mark
