Hello!
I just bled all my brakes and on tightening the last bleed nipple it sheared straight off.
Does anyone know what the part number is or what kind of bleed nipple a C15 2003 1.9. takes?
Many thanks
G
Citroen C15 1.9 2003. Brake bleed nipple
doctle
- x 225
Re: Citroen C15 1.9 2003. Brake bleed nipple
Any motor factor will have bleed nipples they are pretty cheap
Oh buggle
van ordinaire
- (Donor 2017)
- x 402
Unless you are very lucky, you won't get the remains out so you might as well get a caliper & have done with it.
Citroens:-
'81 2CV Club
'05 C15
'97 Xantia Exclusive estate
others:-
Jeep XJ Cherokees x 3
'96 Cadillac Eldorado
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
doctle
- x 225
If the brakes were bled before it snapped you're probably ok for a while. Don't overtighten the bleed nipples it's enough to just sweeten them slightly after they are screwed in fully.
Oh buggle
- x 3304
When I had to loosen off the bleed nipples I would fully undo them and then (carefully!) smear a little copper slip grease onto the threads. I made sure it was JUST on the threads, so it did not contaminate the LHM fluid.
doctle
- x 225
Hell Razor5543 wrote: 24 Jul 2019, 11:03 When I had to loosen off the bleed nipples I would fully undo them and then (carefully!) smear a little copper slip grease onto the threads. I made sure it was JUST on the threads, so it did not contaminate the LHM fluid.
My mechanic recommended ceramic grease, I been using red grease on brakes for a while it's supposed to not damage seals and won't react with brake fluid.
Oh buggle
van ordinaire
- (Donor 2017)
- x 402
Hadn't occurred to me it might've sheared tightening it; in my experience it's usually breathing on them prior to trying to locate a spanner on what's left of the flats. For that reason I avoid bleeding brakes (clutch slaves never seem to be such a problem) if at all poss.
If I have to AND am lucky enough to free off a nipple (& on assembly of new components) I've also applied a smidgeon of copperslip.
"Ceramic grease"? Really, well that's a new one on me!
Citroens:-
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
doctle
- x 225
van ordinaire
- (Donor 2017)
- x 402
Thanks, but I only professed to total ignorance of the product - but then did do a little research to cure that. Never did look at availability though - &, looking at the price, think I'll stick to copper (or ally for stainless). I'll keep an eye out at autojumbles though.
Citroens:-
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
