Hello. Fred starts fine except she rattles madly. Sounds like a loose exhaust, it’s very loud. Once started it’s quiet. With a warm engine the rattle at startup is not as bad but is still there. The exhaust is secure.
I’m wondering if an engine mount would cause this?
Ta.
Xantia - rattle on starting
Jaf
- x 42
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
doctle
- x 225
Jaf
- x 42
Re: Xantia - rattle on starting
Ooh good idea. Will check later when it’s cooler. Probably September!
doctle
- x 225
I heard on the radio England is getting Oz outback temperatures only 23c here but 97% humidity makes it hard to get comfortable, I have an urge to drink ale
Oh buggle
- x 5654
30?C here, more than plenty.
Had to take a bus to get the car and it must have been 40?C onboard. Still recovering.
- x 1751
If a hammering (rather than a rattle), check that the oil filter is the correct type, with a non-return rubber diaphragm below the holes on the filter base. This non-return 'flap' valve ensures that oil does not drain out of the filter when parked up, causing temporary oil starvation for a few seconds when the engine is restarted. Some cheap filters are not equipped with the device.
