Needing the part number of diesel injector seal for Citroen C4 Picasso 1.6 HDi
cargeeka999
Unread post by cargeeka999 »
Hi Im in need of the part number of a diesel injector seal for Citroen C4 Picasso 1.6 HDi year of manufacture 2007.
I have tried ordering with the dealer, but they can get them in right now due to some kind of shortage. Im hoping that I could find a seller online that might have stock, but I want to be sure its the right part.
x 6946
Re: Needing the part number of diesel injector seal for Citroen C4 Picasso 1.6 HDi
Post your VIN up if you want the part number.
cargeeka999
GiveMeABreak wrote: 20 Jul 2019, 17:21 Post your VIN up if you want the part number.
Its here:
lotrjw wrote: 14 Apr 2019, 18:10 VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
x 6946
Here you go:
item (8) is the injector protector - Part 1609848080 £4.60
Item (9) is the injector seal - Part 1609848280 £5.77
Citroen prices inc. VAT when in.
cargeeka999
GiveMeABreak wrote: 20 Jul 2019, 17:31 Here you go:
Thanks that looks like exactly what I need, except I could do with the part numbers of 7 and 13 as well just in case. Citroen said they were able to get 3 of those 4 parts, but if a seller has all four online I might as well order from them instead.
I need all 4 of them as I couldnt even see them when I took the injector out!
x 6946
Item (7) is the Engine injector seal and that is part 1610564580 (Additional info: 7,3/16 EP 2 CN)
Citroen do a 4 pack of these (Part No: 198173)
Item (10) is the Fork and is Part No: 1609848680
cargeeka999
GiveMeABreak wrote: 20 Jul 2019, 17:40 Item (7) is the Engine injector seal and that is part 1610564580 (Additional info: 7,3/16 EP 2 CN)
Is this the right pack; https://www.ebay.co.uk/itm/264291487183 I found that using one of the part numbers you gave in google.
Edit:Actually just checked and the 4 pack part no you gave is on that ebay listing so it must be right. Thanks for your help.
x 6946
No worries
x 1240
Unread post by Peter.N. »
cargeeka999
Thanks for help on this the parts arrived from Ebay and are all installed in the car now, working fine.
