Coolant problem
zalman
Coolant problem
Unread post by zalman »
Hello All,
My car is Citroen C5 2007 2.0 petrol,automatic.
In the morning when i turns on the cold engine i have the following problem : coolant temperature gauge is immediately on top red and cooling fan comes on. The car barely carrying.
Anyone know the problem and how to cure it ?
x 6945
Re: Coolant problem
It's probably the engine coolant temperature sensor that's faulty.
x 1746
Re: Coolant problem
That's what would happen if the temp sensor was disconnected.
Could either be a poor connection, or (as Marc says) a faulty sensor. Easily replaced.
x 1459
Re: Coolant problem
Unread post by xantia_v6 »
I think by that date there would only be a single temperature sensor which also feeds the engine ECU, which would get quite upset not having a valid temperature. I think that the problem may lie elsewhere, perhaps in the A/C system. You really need to have the fault codes read to know what is going on.
zalman
Re: Coolant problem
Thanks for all the replies.
