Wasting my time
- x 2943
Wasting my time
My scanner reports fuel neck sensor fault so I replaced it, it didn't fix it, I acquired the DPF ECU listed in Service Citroen new old stock, climbed under to fit it this morning, there no such thing in the place shown in the picture, so am I being wound up or is it somewhere else?
Item 20 in the image.
- x 6958
Re: Wasting my time
Oh, come on Gibbo, it's obvious from the diagram that it's behind the dashboard, to the left of the blower motor is't it?
- x 2943
Re: Wasting my time
Aaaaaagh!
- x 2943
Re: Wasting my time
Harlequin
- x 24
Re: Wasting my time
If its fitted, yours will be in the OS sill by the rear door. move the carpet to check as its accessed from within the car itself
- x 6958
Re: Wasting my time
For the restyled C5 (MK II) it is to the left of the blower. If you have the version without the fuel cap sensor, then the engine ECU controls the additive pump. As he's having issues with the 'cap sensor', then almost a certainty he has the cap sensor version and therefore the separate additive ECU that on the C5 MK II is where I said.
Harlequin
- x 24
Re: Wasting my time
Had a similar fault on my 2002 2.2 HDi, which is why i replied thats all. Mine needed the cable replacing between the filler cap and the additive pump - £100 for the part
- x 6958
Re: Wasting my time
That's a MK I and the location was different for the additive ECU on those models.
usually bottom of the 'B' pillar right hand side. I was just trying to save Eric from tearing up the interior of the car looking for something that won't be there - as he's already been round the houses under the car looking for it
- x 2943
Re: Wasting my time
It had the warning, first thing I looked at was the cap which was missing one of the magnets, then the cable from the neck to the connection under the pump cover still not fixed so moved on to this part.
It still says it's a cap sensor problem so I'm wondering if the 'new old stock' neck cable is faulty.
Too busy with other stuff today but if it remains dry tomorrow I'll have another go at it.
At least after getting underneath I know the additive tank's not empty
- x 6958
Re: Wasting my time
On systems with a separate additive ECU like yours, it also controls the fuel cap sensor - so if you are having issues with that, the ECU is still your best bet.
That's one of the reasons why they got rid of these additive ECUs as they were more trouble than they were worth - they moved control of the additive functions to the Injection ECU on later models.
- x 2943
Re: Wasting my time
Well I got that fitted, it was where Marc said it was, need an hour for my back to straighten up now before I get the scanner out, not too difficult apart from the acrobatics and then having to find the 10mm socket that decided to go and hide somewhere behind the trim.
- x 6958
Re: Wasting my time
Well no more pilates needed after that I suspect - BUT - did you remember to write down the quantity of additive injected into the DPF stored in the last ECU?
You'll need to programme that in for the new one. If you didn't or can't remember, then here is the guide:
You may also need to tell it of your engine type (DW10BTED4), Gearbox type, etc. The values would of been stored in the old ECU.
| Distance Travelled by the Particulate Emission Filter | Quantity of Additive Deposited in the Filter (In grams) |
| 0 kms (0 mile) | 0 g |
| 10 000 kms (6 250 miles) | 8 g |
| 20 000 kms (12 500 miles) | 16 g |
| 30 000 kms (18 750 miles) | 25 g |
| 40 000 kms (25 000 miles) | 33 g |
| 50 000 kms (31 250 miles) | 41 g |
| 60 000 kms (37 500 miles) | 49 g |
| 70 000 kms (43 750 miles) | 58 g |
| 80 000 kms (50 000 miles) | 66 g |
| 90 000 kms (56 250 miles) | 74 g |
| 100 000 kms (62 500 miles) | 82 g |
| 110 000 kms (68 750 miles) | 91 g |
| 120 000 kms (75 000 miles) | 99 g |
- x 2943
Re: Wasting my time
No joy with that, still the same error codes plus one more 'additive pump open circuit or short to earth' don't take that as read I might have misremembered it when I closed down the scan.
- x 6958
Re: Wasting my time
Ok, but I've assumed you cleared the faults, and then told it you had a new part - and configured it?
