I had to modify the block and make new ends to the pipes. Amazing how much comes out of these pipes when fed by that crazy steering
- x 1996
Re: I am an Activaist-v6 and suffer AX-isum with a touch of CX TurboGTI'itus
Fixed
- x 8397
Stickyfinger wrote: 06 Nov 2018, 21:00 Amazing how much comes out of these pipes when fed by that crazy steering![]()
Crazy but good
- x 1996
Oh dear what have I done !
Now I see the extra space I am thinking I can get another car in there |:) Damp proof membrane to go down, topped with type2 stone&dust (borrowing a "thumper" to compact that)....Cut telegraph pole for one end and the edges/another Damp membrane as a "ground sheet, ply over that, then the Temporary Garage tent (6m/Dancover-Pro) over the top.
My ramps are 5.2 meters long, so with luck I will be able to put a car undercover and on the ramps.
- x 3296
CitroJim wrote: 03 Nov 2018, 11:29
Almost as desirable as an H Van with an ES9 V6 engine and Activa suspension![]()
With four wheel drive as well!
Fake Concern
- x 65
Stickyfinger, is this you?
- x 1996
[New Wheels and tyres to fit ready for France
- x 1996
New Alloys fit, close on the bumyer when low but clear.
225/45/17 TOYO TR1 Proxy (Stiff wall) on et38 wheels.
- x 1996
BUGGERing Truck drivers
The offending jacking block
Crappy Xantia lights (dip)
- x 5672
Bugger bugger bugger
daviemck2006
- x 485
I would use stronger words but the forum would object!
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
- x 6945
So what actually happened - what’s the connection between a trucker and a block of wood?? - apart from being thick.
daviemck2006
- x 485
Has the tyre survived Alasdair
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
Michel
Looks like a piece of wood a trucker would use to put under the feet of the trailer when it's removed to help it stop sinking in.GiveMeABreak wrote: 19 Sep 2019, 12:51 So what actually happened - what’s the connection between a trucker and a block of wood?? - apart from being thick.
That said, unless it was dark, there's no real excuse to hit something that size in the road!
- x 1996
Looks like it, nothing external. Will keep speed down until Sat when it will come off to fix the wheel.
- x 1996
Yep very dark, crested hill and saw hazard lights ahead (damaged Volvo for the same reason) ), add in Xantia headlamps...distracted by the hazard ahead, ....boom
