x 1995
Re: I am an Activaist-v6 and suffer AX-isum with a touch of CX TurboGTI'itus
Unread post by Stickyfinger »
Fixed
I had to modify the block and make new ends to the pipes. Amazing how much comes out of these pipes when fed by that crazy steering :)
x 8406
Stickyfinger wrote: 06 Nov 2018, 21:00 Amazing how much comes out of these pipes when fed by that crazy steering :)
Crazy but good :)
x 1995
Oh dear what have I done !
Now I see the extra space I am thinking I can get another car in there |:)
Damp proof membrane to go down, topped with type2 stone&dust (borrowing a "thumper" to compact that)....Cut telegraph pole for one end and the edges/another Damp membrane as a "ground sheet, ply over that, then the Temporary Garage tent (6m/Dancover-Pro) over the top.
My ramps are 5.2 meters long, so with luck I will be able to put a car undercover and on the ramps.
x 3296
CitroJim wrote: 03 Nov 2018, 11:29
Stickyfinger wrote: 03 Nov 2018, 07:53 Still want an H-Van on a Land-Rover chassis :)
Almost as desirable as an H Van with an ES9 V6 engine and Activa suspension :wink: :-D
With four wheel drive as well!
Fake Concern
x 65
Unread post by Fake Concern »
Stickyfinger, is this you?
x 1995
[New Wheels and tyres to fit ready for France
x 1995
New Alloys fit, close on the bumyer when low but clear.
225/45/17 TOYO TR1 Proxy (Stiff wall) on et38 wheels.
x 1995
BUGGERing Truck drivers
The offending jacking block
Crappy Xantia lights (dip)
x 5672
Bugger bugger bugger :(
daviemck2006
x 485
Unread post by daviemck2006 »
I would use stronger words but the forum would object!
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
x 6945
So what actually happened - what’s the connection between a trucker and a block of wood?? - apart from being thick.
daviemck2006
x 485
Has the tyre survived Alasdair
Peugeot boxer 2016
In the family
Michel
Unread post by Michel »
GiveMeABreak wrote: 19 Sep 2019, 12:51 So what actually happened - what’s the connection between a trucker and a block of wood?? - apart from being thick.
Looks like a piece of wood a trucker would use to put under the feet of the trailer when it's removed to help it stop sinking in.
That said, unless it was dark, there's no real excuse to hit something that size in the road!
x 1995
Looks like it, nothing external. Will keep speed down until Sat when it will come off to fix the wheel.
x 1995
Yep very dark, crested hill and saw hazard lights ahead (damaged Volvo for the same reason) ), add in Xantia headlamps...distracted by the hazard ahead, ....boom :)
