Hello again to all.
Is there still someone on the forum who can get the 4 digit Key Codes for Citroens and Peugeots , by using the VIN ?
Thanks in advance
4 digit key transponder code
xsaras4ever
- x 44
Jumper 2.5d
406 Phase 2 Estate, Hdi
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
Fordson Major Tractor
Nuffield 460 tractor
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
raynoon
Re: 4 digit key transponder code
I too need a code...
1990 G Peugeot 205 CJ
1992 K Citroen ZX 1.9d auto avantage
1992 K Citroen XM 2.1 SD
1993 L Citroen XM 2.1 SD auto
1995 M Citroen XM 2.1td Exclusive auto
1999 Citroen Xantia Break HDi 110 Exclusive
2000 W Citroen Xantia HDi 110 Exclusive
1998 Citroen Saxo 1.0 Open Scandal
- x 1489
I don't think the member who used to do it (The Birdman) is active any more - he used to have a website, and that is off line too. So, Google search, or off to the dealer!
raynoon
Many thanks
xsaras4ever
- x 44
Hello , we got a code today from a member on another forum - it cost £20 - we will let you know if it works.
Jumper 2.5d
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
xsaras4ever
- x 44
Hello , the code worked and we coded both keys.
However, its not a key problem with our car as the key symbol is still lit.
Its a BSI to ECU connection fault............
Jumper 2.5d
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
Stinkwheel
xsaras4ever wrote: 27 Jul 2016, 19:51 Hello , we got a code today from a member on another forum - it cost £20 - we will let you know if it works.
Which website did you use? Can you point us there please?
"Rust Never Sleeps" said Neil Young. Did he own old citroens?
1998 Xantia TD exclusive auto estate +3 x BX's +77' ami 8 break + 73' dyane 6 + '83 2CV6 + 94' XM 2.1 sx auto + 89' XM2.0i
+ '85' GSA + '97 XM 2.0 16v + '81 Visa super E
- x 6945
I suggest you get it from Citroen - for security purposes if nothing else. They will only charge you £25 tops, sometimes less and for that you can get your customer confidential code, the key blade code etc., for the same charge. Plus you know it is secure.
- x 1938
£30 for each of our cars earlier this year.GiveMeABreak wrote: 30 Jun 2019, 11:30They will only charge you £25 tops, sometimes less and for that you can get your customer confidential code, the key blade code etc., for the same charge.
- x 6945
Inflation!
- x 1938
Yup. It was £20 ten years ago for my Mk1 C5.
Stinkwheel
Thanks for the advice Folks, I have indeed approached a friendly specialist and am waiting for them to come back to me with the codes. Seems to be a fair bit cheaper than the 30 quid quoted to others here. I will update you later on if we are successful and the final price etc.
Stinkwheel
Update time, got the codes sorted out for the xantia. It was, in the end 36 quid all in. Which isn’t too bad. Thanks to everyone who got in touch and helped
