Hello everyone,
I have a ds5 2012 and I seem to be having an issue with bluetooth streaming. The calls are working and the music can be heard but there is no information on the screen. It just says the name of the phone I use next to a bluetooth symbol. Do you have the same or is there an issue?
If there is an issue how can it be rectified?
Many thanks
Panos
Bluetooth streaming
Moderator: GiveMeABreak
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: Bluetooth streaming
Panos, the RT6 does not display track or other info with the bluetooth streaning profile. It is not supported. It should however display this information when playing from a USB source instead.
- My Cars: Only 1 French car owned :2012 Citroen DS5
Others:
2014 Ford Mondeo Titanium Business X
2014 Volvo V40 R Design
2008 BMW 118D
2005 MG ZR 160
1998 Opel Astra OPC - x 3
Hi Marc,
Thank you for your reply. Even if I plug my android via USB it still doesnt display anything...I read about the citroens of that year only supporting iPhones and blackberries and not androids but was hoping a firmware update would sort that. I think I was overly optimistic
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
If you have a USB socket in the DS5, then plug in a memory stick with your MP3 files and they should work. Some Apple music players may be compatible (depending on software and the firmware of the RT6). Check your car manual - it will state the formats and more importantly the bit rate that the unit supports.
