good evening all,
I had my c4 with the garage today, for that abs rubbish that is still haunting me
the guy said there was a ton of fault codes up,
i didnt even bother to ask him what they were,
however he did tell me that my ECU has a problem
can anyone shed any light on this , do ECU's give trouble ?
anyway any help or suggestions would be greatly welcomed
regards Keir
ECU Problem maybe
- x 3306
Re: ECU Problem maybe
I would take it to a different garage, for a start. There are numerous ECUs in a car, and without knowing which one has the problem it would be impossible to say what the problem is.
- x 6956
Keir wrote: 28 May 2019, 20:58 good evening all,
regards Keir
Keir - The idea is that there are lots of individual ECUs over several data networks on the vehicle. They are controlled by a master computer if you like called a BSI. When something goes wrong the ECU can inform the BSI and if appropriate, it will store a fault code, that can later be retrieved with a diagnostic tool, to help troubleshooting.
The ECUs are rarely at fault - but the components they control can fail like anything else. It would of been helpful to have a list of the fault codes, as we could of helped with troubleshooting. What is important is that you have a competent mechanic or garage that understands that fault codes can be symptomatic of another component further up or down the line. So if one component is failing, it can pass on incorrect data or no data at all to another ECU that relies on it to do its particular job. If the second ECU gets faulty or no data, then that ECU can flag up a fault.
So it's important to understand all the related faults and use these as a guide to try and get back to the main culprit. So don't immediately think that there are lots of issues - it may simply be one component.
Keir
yes agree with you GiveMeABreak
im not well up on car eletrics as it were, at all,
however I usually start with sensors when stuff goes worng.
I didnt get the chance to see the fault codes as i wasnt there,
so where to go from here ive no idea
- x 6956
So the first step is to get it diagnosed (preferably by somebody with a Lexia diagnostic tool). Run a global test and record all the fault codes. Post them up here and we can start to see what each says which will give you a clue to troubleshooting. This is what a garage would normally do. There's not much we can do here without them to be honest.
Keir
Good morning all
Marc can you tell me how to upload an image please?
Keir
Front right speed sensor
Deviant
Permanent
Engine control unit, absence of clearing of the ASR/MSR
reference value
Permanent
Deviant
Permanent
reference value
Permanent
- x 1938
Keir
Cheers Paul. I posted the faults manually
- x 1485
Ah, a deviant ABS sensor
You really need to see the live data to see what the ECU is (or isn't seeing). The fact that the light goes out suggest that the sensor passes its initial resistance check, but then the signal is not coherent somehow. Has it had a new wheel bearing? I'd have a very good look at the back of the bearing to see if there any signs of distress on the mag track, they can be easily damaged.
- x 6956
Keir - I really need the fault codes to be able to help
Keir
Thank Richard and Marc.
I don’t have access to the actual codes
I’ll see what I can get dug up
tyronejohn
- New User
Hi all!
I see there hasn't been much activity on this forum in a couple of years.
I am wondering if someone could help me out with the faults that have appeared on a Peugeot 208 that I have.
A lot of these faults seem relate to the ECU - I have posted the photos below of the relevant fault codes.
I am a bit of a car novice but can anyone advise if these are worth fixing or even on the cost / time to fix?
Thanks a mill!!
Thanks a mill!!
Ross_K
- x 110
That's a lot of codes
See the printer icon on the tablet screen? If you click that you can save the report as a text file and upload it here. It's a bit easier on the eyes that way
- x 1485
Most are showing intermittent, and that is the sort of blizzard you get when the battery is low. What's actually up with it? I would clear all those out and then see what comes back.
