Wheel tracking "computer says no"
aerodynamica
- x 215
I think the tracking is off on the Xantia ever since I changed the strut tops and lower arm bushes a month or so back.
I called into National tyres and after asking what car it was, said they couldn't do the tracking on them because they're too old!
It's only tracking!
It seems that they have to put in the computer system what make and model it is and it does it for them but if the info isn't in the database it can't be done..
I only wanted to know if it was out because the car feels really wayward despite new bushes, strut tops, ball joints, tyes and the rear arm bearings less than 2 years ago.
It's only tracking!
Graeme M
- x 1751
Re: Wheel tracking "computer says no"
Sounds like another bit of skill lost, Graeme, along with balancing centreless wheels!
Apart from another tyre fitter, you could try your Citroen dealer - those here have a tyre service bay, and don't charge much more than competitor tyre fitters.
Tracking data should be in the Private Cars 2001 book, if you need it.
- x 6955
I would just add, that even ATS with all their new Carlos Fandango, computerised, laser tracking super expensive mega station wrecked my MK II C5 tracking a few years ago! The new set of tyres I had at the same time wore out in a month and were shredded to the wires!
Took it back to complain bitterly and that resulted in them shutting their machine down until the engineers could come out and calibrate it. After that, they had to get the Citroen senior technician out from the dealer next door to tell them how to balance a C5! Apart from the machine being faulty, I expect they did not set the car up properly and also put the wrong model into the system.... Joy
- x 1448
I have the alignment specifications for the mk1 Xantia should you need them.
aerodynamica
- x 215
xantia_v6 wrote: 18 May 2019, 12:23 I have the alignment specifications for the mk1 Xantia should you need them.
Hi thanks, that's would be great if thou could send the specs. I haven't checked whether the Haynes book had anything mentioned.
Graeme M
- x 1485
Buy a Trackace tool and DIY. http://www.trackace.co.uk/index.html One of the staff writes on Practical Classics described using it, and getting a good repeatable result.
Can get it from e-bay for <£75 - not much more than a couple of trips to the fast fit place - ATS seemed to want huge amounts of money last time I was there unless I was mis-reading the poster! Trackace from e-bay
In the absence of any figures, I would set 1-2° toe in on a FWD car, this way when the suspension loads up and pushes the wheels back they will tend towards parallel. Pretty sure Haynes gives figures for MK1 Xantia.
- x 1751
Xantia steering geometry (running height, tracking, etc) data here:
viewtopic.php?f=3&t=61218#p590278
"Private Car books, 2001 - Xantia, XM, Synergie"
pp215–217
pp215–217
- x 1448
That agrees with the info that I have, but for completeness, cars manufactured before the 1996 model year had the king pin inclination specified as 13° 20? ± 30? and cars without power steering before the 1996 model year had castor angle of of 1° ±30?
That was a good excuse to test the symbols in the post editor.
- x 1751
aerodynamica
- x 215
aerodynamica
- x 215
I've taken richardW's advice and took a chance on one of those trackace things. It arrived on Tuesday and after a few quick trials that didn't work out I got to grips with it and it actually works very well. It shows that the front end is 1/3 of a degree toed-in. Two seperare measurements confirmed so it is wrong but I didn't think this was by much . I looked at the track rods and the off side one has a full thread more than the n/s one. I adjusted the o/s one in by half a turn (thread pitch is 1.5) refitted everything and rechecked and it's now 1/3 of a degree toed out that's close to what it's meant to be so i took it for a spin and it immediately feels better and the centering of the steering is stronger. Also have a perfectly straight - ahead steering wheel. Im quite surprised at how little it had to be out to have such a large effect.
The trackace thing is actually very good although you must spend time doing everything perfectly...
Im not sponsored by trackace
Graeme M
aerodynamica
- x 215
I'm going to check the DS's tracking now because i felt it was overly 'twitchy' on the road back from Coventry 2 weeks ago...
Probably check all the cars in the street too
Graeme M
- x 2941
That track ace reminded me of my Dunlop alignment tool back in the sixties.
Still available apparently...at a price.
https://www.ebay.co.uk/i/232442448792
The cheapo Gunsons one worked pretty well
- x 1240
My tracking 'computer' consists of a length of threaded inside a metal tube, I adjust the length until it just touches the inside if the tyre at the front and there is a couple of mm gap at the rear, works every time, at least I never have trouble with uneven tyre wear and I have used it for the last 40 years or so. Doesn't work very well with four wheel tracking though.
- x 1938
I still have one of those! The rubber eyeshield melted years ago but otherwise it's fine.Gibbo2286 wrote: 14 Jun 2019, 09:38That track ace reminded me of my Dunlop alignment tool back in the sixties.![]()
