Citroen - Relay - Bluetooth problems
This section is for General Enquiries or for Systems not Covered Above
x 6954
Re: Citroen - Relay - Bluetooth problems
Post your VIN up and I’ll check what system you have fitted.
Robert16
Unread post by Robert16 »
x 6954
Yes confirmed these are Fiat head units, so I can’t help you with them to be honest.
Robert16
Will do mate . Am taking van for a plug in check on thursday
Robert16
Ok thanks . I'll try the local garage if no luck . Main dealer, not too fussed about having no Bluetooth but the flashing mileage is doing my head in.
x 5645
Robert16 wrote: 14 May 2019, 13:34 Ok thanks . I'll try the local garage if no luck . Main dealer, not too fussed about having no Bluetooth but the flashing mileage is doing my head in.
That sounds as though it is telling you it is due for a service.
x 6954
On these it indicates a Bluetooth issue with the phone module Steve. It’s the Fiat units that have issues and need some Black Magic Voodoo intervention to fix.
Robert16
Lol where can I get this black magic from ...
Robert16
Give me a break will a proxy alignment get rid of the flashing odometer
x 6954
Hi Robert, I very much doubt it - but I cannot tell you what is inside the Technical Service Bulletin that I refer to in my earlier post:
viewtopic.php?f=48&t=58900&start=15#p601001
The dealer should be able to do it assuming the faults specified are coming up along with the flashing on the display. I doubt a simple BSI reset or Proxy Alignment will suffice to be honest as they wouldn't warrant a return to the dealer to simply do that.
Robert16
Thanks I’ll keep you updated
Robert16
No luck with the local garage..
How hard would it be to find a garage able to sort it without going to main dealer.
Willing to travel to get if sorted
x 6954
Very few - other garages very likely won't have access to the procedure and certainly won't have access access to the PSA database servers if a software fix or update is needed. By the time you've been around the houses, you may have been better off getting it sorted directly. I didn't expect a local garage to be able to sort this to be honest.
Robert16
Van is booked in for 31st may will keep you updated..
Junks
Unread post by Junks »
Have the same problem with my newly acquired 2013 Nemo so looking forward to the answers to this :/
