Citroen - Relay - Bluetooth problems
- x 6945
Re: Citroen - Relay - Bluetooth problems
Post your VIN up and I’ll check what system you have fitted.
Robert16
- x 6945
Yes confirmed these are Fiat head units, so I can’t help you with them to be honest.
Robert16
Will do mate . Am taking van for a plug in check on thursday
Robert16
Ok thanks . I'll try the local garage if no luck . Main dealer, not too fussed about having no Bluetooth but the flashing mileage is doing my head in.
- x 5673
Robert16 wrote: 14 May 2019, 13:34 Ok thanks . I'll try the local garage if no luck . Main dealer, not too fussed about having no Bluetooth but the flashing mileage is doing my head in.
That sounds as though it is telling you it is due for a service.
- x 6945
On these it indicates a Bluetooth issue with the phone module Steve. It’s the Fiat units that have issues and need some Black Magic Voodoo intervention to fix.
Robert16
Lol where can I get this black magic from ...
Robert16
Give me a break will a proxy alignment get rid of the flashing odometer
- x 6945
Hi Robert, I very much doubt it - but I cannot tell you what is inside the Technical Service Bulletin that I refer to in my earlier post:
viewtopic.php?f=48&t=58900&start=15#p601001
The dealer should be able to do it assuming the faults specified are coming up along with the flashing on the display. I doubt a simple BSI reset or Proxy Alignment will suffice to be honest as they wouldn't warrant a return to the dealer to simply do that.
Robert16
Thanks I’ll keep you updated
Robert16
No luck with the local garage..
How hard would it be to find a garage able to sort it without going to main dealer.
Willing to travel to get if sorted
- x 6945
Very few - other garages very likely won't have access to the procedure and certainly won't have access access to the PSA database servers if a software fix or update is needed. By the time you've been around the houses, you may have been better off getting it sorted directly. I didn't expect a local garage to be able to sort this to be honest.
Robert16
Van is booked in for 31st may will keep you updated..
Junks
Have the same problem with my newly acquired 2013 Nemo so looking forward to the answers to this :/
