Citroen C5 -05 DMF to "SMF"?
x 5586
Re: Citroen C5 -05 DMF to "SMF"?
Is there no Valeo option?
Pappi
Unread post by Pappi »
myglaren wrote: 22 Apr 2019, 11:56 Is there no Valeo option?
The Valeo-kits I have seen have all been conversions to single-mass flywheel. Valeo seems to think it is a good idea to convert to SMF...
Sachs seems to make pretty good quality, been reading reviews. And they have a full kit with flywheel, clutch, screws/bolts and even grease is included. All OEN matches my car in that kit.
x 1750
The point I was making was that a conventional clutch (cover, friction plate and release bearing) would not be sold with a flywheel as part of the kit - simply because conventional flywheels do not need replacing!
That's why I said your item looked like an SMF conversion kit, not least because these have conventional sprung clutches.
Good luck with your repair.
x 6956
myglaren wrote: 22 Apr 2019, 11:56 Is there no Valeo option?';
That's the one I linked to for a Valeo clutch:
GiveMeABreak wrote: 22 Apr 2019, 10:30 Yes, we can't really comment on third party vendors - that has to be your decision - you have the Citroen part numbers, so just need to search on those.
Genuine DMF:
https://www.ebay.co.uk/itm/NEW-GENUINE- ... 4051399237
Valeo Clutch:
https://www.ebay.co.uk/itm/Clutch-Kit-3 ... ctupt=true
Pappi
Can't be bothered to read any more about flywheels and clutches, at some point it's enough and I've reached it :) Couldn't make up my mind if I should get LuK or Sachs kit for a while.
I ended up with the LuK set that includes 0532-T0 flywheel and 2052-N2 clutch-kit. They had a easter campaign with 23% off.
Thanks for all your input guys, I really appreciate it! Now I know much more about clutches n stuff :)
Now I'm just hoping the installment goes well, and I'll be driving this C5 many miles more. Will need to top up the eolys soon though. Only about a level of 10mm left in the tank... But that's another story.
