C4 VTS - Tire pressure not monitored fault
- x 8
Hi
I got the message "Tire pressure not monitored fault" . I guess it is because the tire pressure sensors are out of power ( the car is 12 years old ) . I know that a tire pressure sensor is sealed. Is there a way to replace the battery although it is sealed i.e pilling the seal ? Or I the tire pressure sensors should be changed to new ones ?
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
- x 64
Re: C4 VTS - Tire pressure not monitored fault
lancia58 wrote: 18 Dec 2018, 17:56 Hi
I've never heard of anyone managing to put new batteries into the sensors only replacing the whole thing. Also they need to be coded to the car with not only Lexia, but also something refered to as an exciter I believe so that the car knows which wheel is which.
- x 8
Hi,
Found this on youtube
Reason: YouTube link
- x 6919
A bit of a mess that to be honest and I wouldn't count on it lasting that long - they have also probably changed the design since 1997.
- x 8
Hi
I replaced the faulty TPMS with a one I got from ebay. It turned out that if the TPMS was activated the TPMS receiver paired with it automatically . How ever I was curios and used Lexia to explore the deflation screens
This was the first screen
Then this was the second screen
And this was the third screen. I did it for the front right and left TPMS and it turned out that after doing this procedure the front left and right receivers lost communication with the TPMS
When I activate the tests I got the following message.
Anyone knows what should I do in order to "wake up" the front left and right TPMS ?
- x 6919
The Lexia should not be used to experiment.
You have started a procedure to pair the modules or activate the sensors, which requires an Exciter tool to work in conjunction with the Lexia.
If you have started the procedure you may have wiped out the previous pairing.
Nothing you can do now except take it to a garage that can pair the TPMS sensors to the TPMS ECU that has the equipment to do this.
One last thing you can try before that is to exit out of the procedure and take the car for a drive for 10 to 15 minutes. That may be enough for the system to reinitialise. If it still throws a wobbly, then you need to revert to my last recommendation.
- x 373
When I had 2 of mine changed for standard valves, I asked the garage how they paired new ones and they said they 'cloned' them. They do tyres on many makes and don't have diagbox. If yours are dead though then I presume they can't be cloned. I kept my old one's that physically broke so if I replace them I could possibly have them cloned. Has anyone heard of this 'cloning'?
Pete
- x 8
Hi,
Yes I did took the car for a drive for 10 to 15 minutes, but it did not help. I guess I will not experiment any more with the Lexia
. I'll go to a tire shop hope they can re-activate it.
- x 8
Is the tool in the following link is the required tool
https://www.banggood.com/EL-50448-Car-T ... rehouse=CN
- x 6919
moizeau wrote: 21 Apr 2019, 19:20 When I had 2 of mine changed for standard valves, I asked the garage how they paired new ones and they said they 'cloned' them. They do tyres on many makes and don't have diagbox. If yours are dead though then I presume they can't be cloned. I kept my old one's that physically broke so if I replace them I could possibly have them cloned. Has anyone heard of this 'cloning'?
That’s different Pete and only applies when you are having the existing sensors replaced, as in when the battery finally dies. Instead of pairing them, they clone the existing sensors so that when the new one goes back on it works like the old one. It’s only relevant to this scenario.
If he has inadvertently wiped the programming from the ECU, then that won’t make any difference as cloning a sensor won’t change what info is stored ( or now possibly not in this case) in the ECU.
- x 6919
No idea. I wouldn’t bother buying one. TPMS sensors last years and years (as do the batteries). Just take it to a tyre fitters - or Citroen. It shouldn’t take them long to re-pair it.lancia58 wrote: 21 Apr 2019, 20:08 Is the tool in the following link is the required tool
- Donor 2023
Just bought one of those EL-50448 off eBay for A$8.47. Says it's GM cars only, but other sellers say GM or Ford, others only refer to the Mhz. If I remember I'll let you know.
Don't want to have to go to the dealer every time I rotate tyres. I think my car already has its TPMS messed up as it throws up a warning every now and then.
2015 C5 Limited Edition (2.2 HDI) 150 kW 450Nm (Racechip S 179kW 528Nm)
- x 6919
Batteries can last about 10 years, before the sensors need replacing.
If the TPMS is notifying you of a fault - do check as they are very often right and are doing their job. They will detect under inflated tyres as well as punctures.
Did you succeed activating the sensors eith the EL-50448 tool?wfdTamar wrote: 11 Nov 2019, 05:29 Just bought one of those EL-50448 off eBay for A$8.47. Says it's GM cars only, but other sellers say GM or Ford, others only refer to the Mhz. If I remember I'll let you know.
I have the same problem and was wondering if this exact tool works on Citroen. As on spec it says it works with 315 and 433 mhz but I will wait it around 2-3 months in order just to test it. So please can you tell it it works. Thanks.wfdTamar wrote: 11 Nov 2019, 05:29 Just bought one of those EL-50448 off eBay for A$8.47. Says it's GM cars only, but other sellers say GM or Ford, others only refer to the Mhz. If I remember I'll let you know.
