Hi, I've read some of the previous posts on this subject and I have a similar problem I'm hoping someone can shed some light on. Not long ago the SatNav stopped showing the progress of the vehicle i.e. it would show the whole route but the vehicle arrow never moved from the point of origin. I did a factory re-set which appeared to fix the problem, but the moment I navigated away from the screen (to reset the clock), the arrow 'froze' to the spot and wouldn't move. Now, reset or not, the screen stubbornly just shows the arrow against a green background with no detail, unless you zoom out to max and then there appears to be a bit of coastline, suggesting the arrow may actually be over Paris! The system appears to know where it is, will accept a new destination and provide directions. It is currently seeing 7 satellites and localisation is 'good'. Unit Ret is 4, Maps are Europe 2009/2010 v1.0 and the software is D_R20ter__R20.07.
Clearly needs a software update, but could this be a firmware issue or is it something more terminal?
Thanks,
John.
C5 SatNav lost map
Johnno
C5 SatNav lost map
John
'59 C5 2.2 173 VTX+ saloon, Jaguar 3.8 MkII 1961
RIP - '07 C5 2.2 173 VTX+ Estate
- x 6945
Re: C5 SatNav lost map
Your firmware and maps are well out of date.
A firmware update (in increments) may help. If you want the updates send me a private message.
