Xsara 15 inch wheels on a c3
- My Cars: 03 Renault Clio 1.5 dci Expression, 05 Saab 9-5 Aero Estate
Was wondering if the wheels off my xsara would be ok to put on my OH's C3, the xsara wheels are 15 inch. Tia.
- (Donor 2017)
- My Cars: Citroen C5 2.0 Hdi 2003
- x 39
Re: Xsara 15 inch wheels on a c3
They will physically fit, inasmuch that they have the correct centre bore diameter and stud hole pattern. But whether the offset is acceptably close I don't know. Easiest thing to do is probably stick them on the car and have a look.
Sam
2003 C5 2.0HDI 110
2003 C5 2.0HDI 110
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5712
It is important to get the right offsets too - not just the wheel size and diameter.leewesley20371 wrote: ↑09 Apr 2019, 21:12 Was wondering if the wheels off my xsara would be ok to put on my OH's C3, the xsara wheels are 15 inch. Tia.
If you pop up the VIN for the C3 and for your Xsara I can give you the correct settings for each.
C3 VF7**************[VIN obfuscated, can be read by forum staff] Xsara VF7**************[VIN obfuscated, can be read by forum staff]
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
So the C3 is a 1.4 Petrol and your Xsara is a 110 HDi.
The wheels for the Xsara have the following: 6" Wide, 15" Wheel Diameter, with a positive offset of 18 mm
6,00 J15 H2 4-18
The wheels for the C3 Petrol have the following: 5.5" Wide, 14" Wheel Diameter, with a positive offset of 24 mm
5,50 J14 H2 4-24
So they are not the same. I would suggest you seek some expert advice as it is important the the offsets are not too far from the original values.
6,00 J15 H2 4-18
5,50 J14 H2 4-24
Thanks Marc, I might pop over to Citroen and ask them lol
- (Donor 2017)
- x 39
I can't imagine that any expert will give such advice for free given the liability potential, and conversely you can be pretty sure that anyone who does give advice for free in the circumstances isn't an expert. Presumably the expert needed is a vehicle dynamics engineer, who I doubt you'll find in your local Cit garage.
Sam
2003 C5 2.0HDI 110
2003 C5 2.0HDI 110
Right, been to Citroen and they advised me to go somewhere like kwik fit so had a look online and found a wheel offset calculator. Is this an easier way to work it out or would it be better to swap them over and see how it goes ?
- My Cars: 2008 Laguna 1.5 DCi
- x 235
They might affect the handling in ways you wouldn't like. Kwik fit workers know very little in my experience
Oh buggle
- van ordinaire
- (Donor 2017)
- Location: Live & work in London but weekend in Devon (or do I now live in Torbay & work in London?)
- My Cars: Citroens:-
'81 2CV Club (quietly sleeping in a parallel universe)
'05 (yes, really) C15
'97 Xantia Exclusive estate
others:-
'96 Jeep Cherokee Limited - the "donor"
'99 Jeep Cherokee Orvis - the green one
'97 Jeep Cherokee Limited - the red one
'99 Cadillac Seville STS
'96 Cadillac Eldorado ETC
& numerous what might be described as abandoned projects! - x 405
I wouldn't trust Kwik**it to pump-up a beachball BUT I can't imagine 6mm making any real difference.
Citroens:-
'81 2CV Club
'05 C15
others:-
Jeep XJ Cherokees x 3
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
- Timmo
- My Cars: 58 partner teepee outdoor hdi.
58 C2 Code in black! Fun! - x 168
- Contact:
as long as your wheel bolts are suitable - citroen alloys often use a flat bolt face, If the wheels are still on your xsara not an issue, but if not check first, with the 1/2" difference in width and the lower offset you probably wont notice a great deal of difference, the c3 exclusives and sporty models come with 16s as the c2 sporty ones do, i ran my old xantia on 17s with an offset of 25 as apposed to the std steelies on 15, they did tuck in a little but never suffered any rub or ill affects, likewise when i had the Bx16v on the road in the early 00's i ran that on 17s (std on 14s) with no issues for a while then dropped back to 15's after i sold the 17s.
if you have a google you should be able to find a few C3s running the C4 vts Resolfen alloys in 17" , look quite good!!!!
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
- daviemck2006
- My Cars: Far too many good ones to remember. Many BL, Vauxhall, Ford, Renault, Citroen, Peugeot, and now VAG
- x 488
At 6mm difference in offset I would say stick them on and see how they are. I would think they would be ok. Try driving slow going from lock to lock. If they do rub a set of 5 mm spacers may be required but then you would need extended bolts and the wheel may not get properly centered on the hub, which is not a great idea. I doubt if you would get hubcentric spacers at 5mm. And if they fit then inform your insurance as non standard wheels for the car can effect your premium, and not telling them could render your insurance invalid.
Skoda Karoq 1.6tdi 2018
Citroen relay camper 2012
In the family
Seat Leon 1.5tsi tourer 2019 daughter 1
C1 vtr+ 2010 daughter 2
In the family
- van ordinaire
- (Donor 2017)
others:-
Wondered when you were going to chip in Davie - as this seems very much your area
Citroens:-
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
- daviemck2006
- x 488
van ordinaire wrote: ↑17 Apr 2019, 00:34 Wondered when you were going to chip in Davie - as this seems very much your area
Yes, it is one area I have learned a lot of. I usually change the wheels on most vehicles I own, so I check up these things. Im quite fussy about tyres too. If necessary, I mean skint, I will buy budget tyres but that is very rare. I usually buy Falken, Vredestien, or uniroyal tyres. I also alyays fit them in pairs across an axle. I dislike different tyres on the same axle, I think that can unsettle the car. I also always change them at 2mm not right down to the markers which is 1.6mm. That 0.4mm maybe doesnt seem like a lot, but makes a big difference in the wet.
In the family
In the family
- van ordinaire
- (Donor 2017)
others:-
Hmmm, seems we're I've like minds on this but your preferred brands is helpful because my Xantia came on Chinese doughnuts & much as I'd like Michelins that ain't going to happen! The C15 is even more of a conundrum; I read somewhere that they don't like cheap tyres BUT, it is what it is - so some sort of reason has to prevail when the time comes to replace the too good to turn down offer of 2 pairs when I still couldn't be sure I'd cured its voracious appetite for front tyres.
Citroens:-
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
