C5 2010 1,6 THP aut. deceleration noise
mf.lorant
Re: C5 2010 1,6 THP aut. deceleration noise
Hí, me again.
Can someone tell me what this "thing" is for?
- x 6945
Brake Vacuum Pump possibly????
- x 1459
It looks to me like a gearbox breather (vent).
mf.lorant
Can you please tell me what its function is?
- x 1459
It allows a small flow of air into and out of the transmission case so that the case is not pressurised when it gets hot. The vent hole is small (and may be convoluted) so that minimal oil vapour is lost with the air. The flow through the vent is normally very small.
On some transmissions, the plastic vent cap is removed and the hole used for refilling the transmission fluid.
mf.lorant
Wow, thank you
- x 6945
Well spotted Mike.
mf.lorant
Happy Easter
Finally I got the sound on video.
Check at 0:08, this is the sound you should search during the video.
Regards,
Regards,
Reason: YouTube tags
- x 6945
I removed your last post as it was a duplicate of the one above.
I appreciate you may not have had any responses, but to be honest, I did watch it several times and could not really hear anything because of the background noise. The only other noise I can make out is the Auto box.
There was nothing that stood out to me unfortunately, so maybe others have concluded the same.
mf.lorant
Thank you Marc for removing my duplicate post.
I'll leave it as it is and because French cars are very sensitive to faults as soon as something appears it'll give the fault code anyway.
Thanks again for listening.
- x 1938
I've tried to watch it several times but keep getting "An error occurred. Please try again later".
- x 6945
It is playing fine Paul - maybe you need to clear your browser cache.
mf.lorant
Dear all
Please help me again, what does the following (attached picture) stand for? What should I do, and where can I find it? It is a 2010 C5 THP 155HP.
Thank you in advance
- x 1459
The air temperature sensor is (I believe) mounted on the hard plastic pipe that runs across the top of the engine from the intercooler to the throttle body.
Maybe the connector is loose?
mf.lorant
Then it should be this one I hope
