PSA interface checker
goltho
Unread post by goltho »
Hi there. Baby's first post :-D and although I'm new here, I have been round the block a little with Peugeots, software use and motor engineering in general.
We currently have a few 206s in the family (2.0L cc, 2.0L HDi, 1.4L Entice). I bought a Win7 laptop a couple of months ago with DiagBox 7.57 pre-installed and a Lexia connector & leads. It works to a degree but not fully - on all cars. Some modules it reports as having communication issues with and others it connects with but can't identify. It's then a case with the latter of trial & error to find which unit is installed in the car. The ECU (for example) can't be communicated with on any car.
I upgraded Diagbox to 7.83 (highest version I have) in stages this afternoon which went well, but it made no difference to the issues. I'm now believing that the Lexia firmware is out of date but I can't find a link to the PSA interface checker anywhere to check what I've got. :shock: I have read that it was available here via a member(s) - is this still the case? Rev C seems to be what I require - is that correct and does that work with DiagBox 7.83?
Thanks.
Peugeot 206cc / 2005 / 2.0L
Peugeot 206HDi / 2005 / 2.0
Peugeot 206 Entice / 2003 / 1.4
x 3280
Re: PSA interface checker
Hi, and :welc: to the forum. There is a checker, and it shouldn't take long for a Moderator to point you in the right direction.
I would suggest you DOWNGRADE your Diagbox software to v7.57. Later versions have a 'need' to be connected to the PSA servers (I still haven't got my head around this), so may not give you the functionality you are after (but I feel certain a Moderator will explain this a lot more clearly).
goltho
Hell Razor5543 wrote: 16 Apr 2019, 22:17 Hi, and :welc: to the forum. There is a checker, and it shouldn't take long for a Moderator to point you in the right direction.
I would suggest you DOWNGRADE your Diagbox software to v7.57. Later versions have a 'need' to be connected to the PSA severs (I still haven't got my head around this), so may not give you the functionality you are after (but I feel certain a Moderator will explain this a lot more clearly).
Thanks James. I spent most of today researching and upgrading but didn't come across mandatory PSA server connection issues with later versions. #-o However I'm here for knowledge so I'll await further input! I guess downgrading would mean re-installing?
Will the checker indicate whether my Lexia is a clone or otherwise?
x 3280
I cannot help further with the need to be connected to the PSA servers (as I don't have a Rev C unit, so I cannot use higher than 7.15), but I can tell you that (as PSA don't release Lexia equipment to the general public) your Lexia will be a clone. However, so long as it has the full chipset it will be fine.
x 694
Unread post by Mandrake »
What style of connector does the 206 use ? Is it a modern 16 pin OBD-II connector, or is it the older long rectangular 30 pin connector (as used on Series 1 Xantia) or is it just the two prong connector used on even older models ?
goltho
Mandrake wrote: 17 Apr 2019, 09:55 What style of connector does the 206 use
They're all OBDII.
goltho
Is there someone I can PM who would be able to help with the checker? My HDi's MIL came on mid-week but the fault isn't being accessed. :roll:
x 6953
goltho wrote: 16 Apr 2019, 21:46 Hi there. Baby's first post :-D and although I'm new here, I have been round the block a little with Peugeots, software use and motor engineering in general.
We currently have a few 206s in the family (2.0L cc, 2.0L HDi, 1.4L Entice). I bought a Win7 laptop a couple of months ago with DiagBox 7.57 pre-installed and a genuine Lexia connector & leads. It works to a degree but not fully - on all cars. Some modules it reports as having communication issues with and others it connects with but can't identify. It's then a case with the latter of trial & error to find which unit is installed in the car. The ECU (for example) can't be communicated with on any car.
Thanks.
1) I suspect you may not have a full chip VCI - there are plenty of cheaper versions that do not have all the hardware to talk to some full CAN vehicles.
2) The firmware versions are automatically installed correctly as appropriate for the version of Diagbox you are installing.
3) You say
There can be over 25 separate ECUs - which one are you talking about? If you are saying it won't talk to any ECU - then you have a communication issue or as said - the version you have may be too new for the vehicle you are testing.
4) Try reverting right back to version 7.02. That should be the latest version of Diagbox '7**' that an older VCI or revision 'B' interface should work with - depending on the interface you have - but is a good indication if it starts to work.
If the vehicles you are working on are 2008-on and it won't talk to the newer cars - I suspect you do not have a full-chip kit. Typically, but not all of these 'knock down' kits will be anything in the £40 - £80 price bracket (excluding. laptop of course). Many of the full chip kits with all the hardware will be in the £100+ price range.
So as you bought the whole kit - was it new or second hand from somebody -the point being do you know what revision / quality of kit you have?
Does the green light stay on when communicating with the vehicle? If the 206s you are trying to diagnose are 20005 models, the interface should be launching Peugeot Planet 2000 for this year - so can you confirm the Windows 7 version on your laptop - is it 32 or 64 bit version?
goltho
GiveMeABreak wrote: 17 Apr 2019, 10:45 1) I suspect you may not have a full chip VCI - there are plenty of cheaper versions that do not have all the hardware to talk to some full CAN vehicles.
3) You say "The ECU (for example) can't be communicated with on any car." There can be over 25 separate ECUs - which one are you talking about? If you are saying it won't talk to any ECU - then you have a communication issue or as said - the version you have may be too new for the vehicle you are testing.
Hi Marc,
1) Understood
2) Not clear on this - that would depend on the software and the Lexia being purchased together originally?
3) My bad, sorry - the engine ECU and Injection ones being the chief problem.
4) I'll try reverting. I presume I'll have to uninstall and reinstall from scratch? I do have all the files.
I only work on pre-2006 vehicles. Can I tell whether it's a full chip kit by opening it?
Second-hand, already installed and (allegedly) working. I don't know what revision I have.
Yes, green light stays on. All cars I've tried it on have been 2005 or earlier. DiagBox has never offered any other option than the Citroen/Peugeot home screen. I will say that I've had to choose 206+ every time as the 206 (or 206MUX) require me to enter the VIN and DAM manually. When I do that, it egg-times and offers me PP2000. When I choose that option, it egg-times and goes back to the PP2000 screen again. I've never managed to run PP2000.
(Description of what I bought was Lexia 3 PP2000 Diagbox 7 9780.Z5. Don't think that'll help.)
Dougie.
x 6953
Ok Dougie let's see if I can address these one at a time:
2) Diagbox 7, when first installed, auto updates itself to version 7.02. It will stay like this until you install further updates. It is not necessary to update it to the latest - as this can in fact reduce functionality on higher versions. So each particular update needs a particular level of firmware. Each software update has the correct firmware contained within the software update and pl;aces this into the relevant folder on your laptop. During the install of each update, part of the process checks the firmware against what is on the VCI and updates it with the correct version for the update you are installing.
If and when you downgrade the Diagbox version, the firmware is again replaced with the correct version for that which you are installing.
Generally V7.58 is the most stable and covers vehicles up to December 2014.
3) No worries - the Injection ECU is incorporated into the Injection system. There is no separate ECU for this. Other examples of ECU include the master controlling BSI, ABS / ESP ECU, Air Conditioning ECU, Climate Control ECU, Audio Head Unit / Telematics ECU, Tailgate ECU, Electric Seats ECU, Airbag ECU, Suspension ECU...... - you get the picture - there is no 'ECU' as such, each is incorporated onto the system it represents.
4a) No - just apply the update you want - and I suggest the from 7.** to 7.58 update. However, as I mentioned in my last post - if you have an older revision unit, you may be restricted to 7.02.
4b) Opening the unit - be very careful as it will void any warranty - but I suspect it is out of date now anyway. Yes you can determine the type of unit:
As you can see the cheaper versions are missing components circled which include Optocouplers........ When compared to a full chip example here
...and again on the other board - missing components......as compared to a full chip kit.
Further on some lesser units, there is a resistor missing arrowed that relates to CAN communication....
Ok, the VIN should be detected - but the DAM number will have to be entered manually - that is normal for both Lexia and PP2000. If it's not picking up the VIN then it's not right. Check that PP2000 is not already launched and hidden on the taskbat - sometimes the interface can obscure PP2000 and you are unaware it has launched but is hidden under the other window - so launching it again causes a problem.
goltho
That's all pretty clear Marc, thank you. Am I better served uninstalling my current 7.83 version and starting again with 7.02 (to 7.58) or can I re-run the 7.56-7.58 upgrade to "downgrade" from 7.83? I think you've answered this already with your 4a) above but just would like confirmation.
The unit is in fact a clone. Pfft.
The VIN is picked up only after selecting 206+. Is this correct for 2002/2005 models? I will check for PP2000 loading as you suggest.
If this works out, I'll be delighted. If it's not going to be 100%, I'll consider replacing the Lexia with a full chip version.
I appreciate your time & input.
Dougie.
goltho
I also have files from a second CD I got with the kit. I can't see that PP2000 is actually installed anywhere. C:\AWROOT contains DiagBox but C:\APPLIC is created but empty?
Dougie.
x 6953
First I would downgrade to the earliest version you have above the main installation of 7.02.
Next, ignore the files and folders on the CD. The installation of Diagbox actually installs both Lexia and PP2000 as part of the package. These are encapsulated software stored and launched automatically depending on the vehicle being diagnosed.
Normal practice is to select he Marque first, then select the model. Then it will ask you to connect the VCI and should then detect the VIN. It will ask you to confirm the VIN. For cars circa 2007 and earlier it will ask you to launch ‘scantool’ or PP2000. If you select PP2000 this is where it can become hidden underneath the main Diagbox window, so do check the taskbar. Then it should ask for the RPO or DAM (build number).
goltho
Soooo.... I was unsuccessful in directly downgrading DiagBox so uninstalled it completely including thoroughly checking and cleaning out the Registry. It took two attempts as the first one failed to complete but second time, PP2000 and Lexia also installed correctly. Now I know for sure that PP2000 has been missing on the laptop from when I bought the kit (which may account for it not loading... :roll: ). I also did the lowest-level upgrade from 7.01 to 7.57.
Tried it today, and voila! Proper connection and functioning by PP2000 on all ECUs. =D> So I am of course more than grateful for your time and help on this Marc.
The MIL came on a few days ago and the pics show issues with the engine ECU. I also get the 3-beep warning now even after clearing the codes. The pics below show the faults, the main one appearing to be the pre/post heating relay circuit which shows the further message when selected. The fan does seem to work on slow speed. Any ideas?
Dougie.
x 6953
Glad you are up and running now :-D
The first fault re the glow plugs is extremely common on HDIs - normally it gives a message about plugs never been supplied which most generally ignore!
Best make a note, read and clear the faults and then re-run a Global Test to eliminate any historic faults. You can then expand these and deal with them individually.
