Towing C5
zeeshanzaki
x 6
Re: Towing C5
Unread post by zeeshanzaki »
Thank you so much for quick response.
I checked mine and can't find it. So might have been lost. Without this it is impossible to load this car on to the tow truck. When the gear stick stuck in the park, we couldn't tow the car and had to fix the gear stick onsite (luckily I found the instruction). I also found it is very difficult to tow when the starter motor died. Once you lift the car and remove the the jack, there is no way to bring the car to normal height without starting engine.
x 6957
Re: Towing C5
The car doesn't need the engine running for minor adjustments - unless you have lowered the car to the lowest height - then it will need the engine running to get it back up - but normally, the car should maintain normal height for you without the engine running. For example when you unlock the car in the morning - it should start to rise to normal height before you even start the car.
See if you can borrow a towing eye - you might find one from another vehicle that fits. Certainly a Peugeot or other Citroen vehicle would be a better match.
x 2941
Re: Towing C5
I've got a spare one but...…………………………..Australia?
How about this.
https://www.ebay.com.au/itm/CITROEN-BER ... wISFazUkC
x 1943
Re: Towing C5
Flip that's expensive! Any scrapyards nearby? And I'm aware that near in Oz is anything up to 500Km.
x 2941
Re: Towing C5
Paul-R wrote: 10 Apr 2019, 11:45 Flip that's expensive! Any scrapyards nearby? And I'm aware that near in Oz is anything up to 500Km.
Oz dollars are about three to a pound, so not very pricey really.
x 1056
Re: Towing C5
Unread post by wheeler »
zeeshanzaki wrote: 10 Apr 2019, 01:01 Without this it is impossible to load this car on to the tow truck.
That's not true, the recommended way to load 90% of cars onto a flatbed is to put a sling around the bottom wishbone & pull on that way (unless the vehicle fault prevents it).
There are some cars, normally high performance & prestige vehicles that use lightweight wishbones that are not recommended to winch on this way, the towing eye should be used in this case with a breakaway strap used on the wishbone.
Also nearly every car with an automatic gearbox I have ever seen has a manual release to get the gearbox out of park for loading. Most are very simple involving simple or no tools, some are a bit more involved.
zeeshanzaki
x 6
Re: Towing C5
This is one from Berlingo and I am sure if it can fit. I will check car wreckers and see if they have.
Gibbo2286 wrote: 10 Apr 2019, 11:31 I've got a spare one but...…………………………..Australia?
How about this.
x 2941
Re: Towing C5
I can't think that Citroen would make too many different types of these, I've only seen two, a long one and a short one and I have both here, they're identical except for the length.
