C?TROEN C5 2011 SX PK 2.0 HD? 163
MikeT
x 232
Re: C?TROEN C5 2011 SX PK 2.0 HD? 163
Unread post by MikeT »
Sorry, I misread "air mixer" to be air heater, which I now believe is the EGR throttle as lI forgot tha later vehicles like yours only have the single air doser.
Same test principles apply.
If you post your VIN number, an accurate diagram can be provided by GiveUsABreak.
sonerpc
Unread post by sonerpc »
MikeT wrote: 05 Apr 2019, 12:44 Sorry, I misread "air mixer" to be air heater, which I now believe is the EGR throttle as lI forgot tha later vehicles like yours only have the single air doser.
is an egr valve you call air mixer.egr valve in my tool exactly where
sonerpc
especially when you need our help you should direct me then we can tell our mechanic GiveUsABreak
MikeT
x 232
EGR valve and Air Mixer (also called EGR throttle or Air Doser) are two separate components. You'll have to wait for admin to provide further VIN-specific information.
This is an example of how they may be represented in the Diagbox tool...
x 6947
He has the Double Air Doser Mike - this is the DW10CTED4 engine with Delphi Injection:
So here are the Air Supply Components:
(1) Air flow meter (Air flow by mass).
(2) The air inlet housing.
(3) Turbocharger air cooler.
(4) Proportional electrovalve controlling the variable resistance turbocharger.
(5) Cold air circuit electrovalve.
(6) Hot air circuit electrovalve.
(7) Variable geometry turbocharger
(8) Double inlet air doser unit .
(9) Inlet air pressure and temperature sensor.
ReferenceDesignation
"a"Turbocharger blades control diaphragm (With position copy sensor)
(1)Engine ECU
(2)Variable geometry turbocharger
(3)Proportional electrovalve controlling the variable resistance turbocharger
(4)Air flowmeter by mass
(5)Air filter unit
(6)Turbocharger air cooler
(7)Double air mixer with position repeat sensors
(8)Inlet air pressure and temperature sensor
(9)Turbo air cooler by-pass control electrovalve
(10)Air metering unit control electrovalve
Key
  • "A" Fresh air
  • "B" Cooled compressed air
  • "C" Hot compressed air
  • "D" Air inlet
  • "E" Exhaust gas
  • "F" Control vacuum
  • "G" Electrical links
EGR Components:
(1) Exhaust gas recycling module :
Electrically-controlled exhaust gas recycling valve
Exhaust gas recirculation heat exchanger
Pneumatic exhaust gas recycling heat exchanger bypass flap
(2) Control electrovalve for the EGR heat exchanger by-pass.
sonerpc
I appreciate you for your interest.
especially givemeabreak and miket your interest makes me happy.
I don't want to bother you so much.I took the pictures you sent out of the printer.my mechanic will go to my friend tomorrow.you know these two p codes
tomorrow I'll spend all day in my car.where should I look at respectively
where do you think to start repairing
I can understand if it has been canceled(partikül filtresi) ?
x 6947
Not sure I understand what you are saying about the Particle Filter being canceled?
sonerpc
GiveMeABreak wrote: 07 Apr 2019, 19:49 Not sure I understand what you are saying about the Particle Filter being canceled?
What should you recommend in a repair shop tomorrow.I just asked the question. Is it understood that the particle filter is canceled.egr valve can be clogged or a sensor malfunction.p I received p error codes related to air agitator.what the experiences show in the engine
x 6947
No, leave the particle filter alone - that is not indicated as being at fault.
Get your mechanic to check the vacuum circuit as described on the previous page where I listed the fault codes. It has the suspect areas listed.
MikeT
x 232
Item 8 (air doser) and item 6 (electrovalve) are main suspects as they are prone to contamination (sticking).
I would test these first (further tests may be necessary).
Item 8 houses two butterfly valves. Clean and check they both open and close smoothly.
If not, replace air doser.
Example
Item 6 is has a very small internal air filter. If internal air filter can be cleaned, clean it.
If not, you may need to replace electrovalve.
Example
sonerpc
I am a mechanic now.
the socket I have marked is idle.could this be related to
Reason: Fixed Image
sonerpc
can't comment.
i am very angry now.
I'm investigating it so empty.
you can not comment so give an idea
x 1943
That's so poetic. Almost like a Haiku.
sonerpc
Citroen C5 is a great tool.
repairers are very weak, this is not enough to solve the problem.
I'm researching it.everyone is helping.then I share with repairmen.
result 0.
x 6947
Please note that on the DW10C engine, the by-pass function is not active, the hot air (by-pass) flap is only activated in the event that the cold air (mixer) flap seizes.
So although you have the double air doser, the left hand plug is purposefully disconnected (the wiring plug will be hidden) and there should be no vacuum pipe attached either. So DO NOT connect this up, as it is designed to be left off!
