I'd just switched the engine off when I noticed a large puddle or browny red and steam from under the bonnet.
What are the most common places to check for to idetify the cause of a large random coolant leak?
Note: the puddle is the wrong consistency for any type of oil and the coolant reservoir is the only one that's empty, so I'm 100% satisfied it's coolant and not something else!
2006 Citroen Xara Picasso coolant leak...
- My Cars: 2006 Citroen C4 Picasso Exclusive Petrol
2008 Citroen C4 Grand Picasso Petrol
2005 Citroen C4 Picasso Desire Petrol
2007 Citroen C4 Picasso Petrol
"Bonjour!", greets my Citroen as I put my key in the ignition, "What would you like to learn to fix today?"
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5646
Re: 2006 Citroen Xara Picasso coolant leak...
You’ll have to trace it back, but obviously don’t get underneath while it’s still hot if you’ve had the engine running. Use a cloth and trace back the leak, it could be a hose it could be the coolant thermostat housing the sky is the limit so you need to do a visual check.
