Citroën Xantias are....
kafkaian
....depressingly undervalued.
Having looked through the latest Autotrader, I cannot believe how cheaper still they have become. Time for the C5 to drop an increment or two does anyone think?
Kowalski
ACTIVE8
- x 6
ACTIVE8
- x 6
Kowalski
Thunderbird
Kowalski
Perhaps it matches it in performance, the 1.9TD can be made to match the performance of the 2.1TD too, I'd still prefer the bigger engine.
The 2.2 is 16 valve, has a bigger clutch and a gearbox engineered to handle the torque and balance shafts too. Its a 2nd gen common rail engine so its smoother and quieter to boot.
There is the question of the Hydractive 3+ suspension, I get conflicting information on which models come with it, some say its the 2.2HDI and the V6, others say the exclusive models only...
The chipped 2.0 would be more econmical than the 2.2 both of them beat the 1.9TD.
I'm sure that the particle filter could be made to disappear or maybe just get given the old straight through broom handle technique and the 2.2 can be chipped to about 180 bhp without breaking stuff.
ScottFromNZ
Thunderbird
imho the Xantia mk2 is a better option than the C5 mk1:
- Classic design thar resists time.
- Better seats.
- Better build construction.
- HDi engines basically the same.
- Less electronics.
- Cheaper (if the price was the same, I would still go for Xantia).
I would go for Xantia mk2 or C5 mk2 2.0HDi, if I had the money.
I would forget C5 mk1 and Xantia mk1.
- Better seats.
- Less electronics.
Kowalski
The Xantia MkII is lighter than the C5 (thus faster), has full power brakes and is available with the Activa system which the C5 isnt, the big downside is the Euro NCAP rating....
The C5's advantages are the 2.2l engine and EBD, emergency brake assist and the availability of Xenon headlights. I'm not sure whether the Hydractive 3/3+ suspension is advantageous. All of the things the C5 has that the Xantia doesn't introduce a load of electronic complexity.
Given the choice (and somebody else paying) I'd go with a C5 MKI over a Xantia MKII. Given that I am paying however, I'll stick with the Xantia MKI for a while yet, then perhaps the C5 will happen when they're cheaper.
I'd agree that the new 16v 2.0 HDI is better than the 2.2, the fuel economy is better whilst the performance is the same.
NiSk
Thunderbird
Rostami
tomsheppard
- x 1484
Au contraire, Tom. On a TD, the more air you can get in, the more diesel you can burn, and the more power you can get out - provided your turbo is big enough of course! Easiest way to do this without excessive boost pressure, is with 4 valves / cylinder. This also gives the advantage of making the head symmetrical, which allows you to put the the injector in the centre - the ideal location for a direct diesel injector. Of course, whether all this is 'desireable' is open to dicussion, but I sure fancy having a go in the C4 with the 138 BHP 2.0 HDi engine.....!!!
BTW, Kowalski, most C5 2.2HDi drivers report consumption around 40 mpg, so no better than a 1.9 TD Xantia - although it should go better!
