C5 (X7) Component Failures /Faults / Replacements Poll
Which of the following failures/replacements (past & present) have you had on your C5 (X7)
A/C Compressor
26
4%
A/C Condenser
27
4%
Alternator
25
4%
BHI (Hydraulic Pump / Motor)
9
1%
Blown Air Module
5
1%
BSI
4
1%
Car Battery (<3 Years)
40
6%
Clutch (< 40k Miles)
5
1%
Clutch (40-80k Miles)
15
2%
Dual Mass Flywheel (<40k Miles)
3
0%
Dual Mass Flywheel (40-80k Miles)
13
2%
EGR Valve
22
4%
Electric Parking Brake
19
3%
Electric Window Regulator
48
8%
Engine Fuse Box
14
2%
Front Height Sensor
7
1%
Front Suspension Pipe
5
1%
Front Suspension Strut
54
9%
Head Unit/Audio/Sat Nav
18
3%
Heater Resistance Module
8
1%
MAF
4
1%
Manual Handbrake Cable
3
0%
Parking Sensor(s)
35
6%
Particulate Filter (FAP)
16
3%
Power Steering Pump
8
1%
Rear Height Sensor
18
3%
Rear Suspension Pipe
18
3%
Rear Suspension Strut
15
2%
Screen Wiper Motor
25
4%
Starter Motor
11
2%
Steering Rack
66
11%
Turbo
13
2%
Tyre Pressure Sensor(s)
21
3%
Vacuum Solenoid
6
1%
Total votes: 626
Lenny
x 63
Re: C5 (X7) Component Failures /Faults / Replacements Poll
Unread post by Lenny »
Lenny wrote: 03 Mar 2018, 22:39 I don't want to tempt fate but my X7 has been brilliant.
I don't 'do' modern cars really and was expecting to spend as much repairing it as my last company car cost (a BMW 120D Sport - hateful thing).
It's been 2 years and 20,000 miles now and I've forked out for an EGR valve (about £150ish I think) when I first got it, then one of the reversing sensors (about a tenner off Ebay and 5 mins to fit) about a year ago.
No leaks, no squeaks, nothing has broken or fell off. Not even had a bulb.
Maybe I've been lucky but the warranty I bought with the car 2 years back has thankfully been a waste of money.
Compared to that awful, unreliable, cramped, uncomfortable BMW this C5 is an absolute dream.
...And another year / 10,000 miles down the line I've still nothing of note to report.
I've serviced it again (genuine parts) and put a couple of tyres and bulbs on it but nothing more.
I sometimes wonder if the ridiculously regular servicing it's received throughout it's life has had some influence?
At the risk of tempting fate once again, I'd go so far as to say it's the most reliable car I've ever ran.
x 6945
Servicing won’t have anything to do with steering racks and hydraulic struts that are the most failing items. These failures are down to poor design and / or how they are applied to the particular vehicle / exposure to the elements.
I’m on my third rack now, but as this has been replaced with a coated one and also had a boot fitted over the pinion, I eagerly await to see if it outlasts the other 2 new OEM ones!
Glad you are problem free at present.
Lenny
x 63
I fully expect a large puddle of LDS to appear the day after the warranty expires.
exasperated
Unread post by exasperated »
Hello All,
I think the idea is a good one,and would like to see it extended to the C5 series 2. Particularly if the distance covered is included.
Regards from 'exasperated'
x 1994
Unread post by Stickyfinger »
Lenny wrote: 22 Mar 2019, 20:49
Remove the inspection plate and have a good look maybe ?
Lenny
x 63
If you mean for the steering rack, I did that a year or so ago after reading about the issues on here.
The pinion wasn't exactly gleaming but I cleaned it up a covered it in Bilt Hamber anti-rust wax.
I know it will go eventually though, and I'm almost willing it to go before the warranty expires!
x 1994
Have another go, fill the depression around the pinion with marine grease and it will not fail.
Lenny
x 63
I shall do that.
Is there a particular brand you'd recommend or is one marine grease pretty much the same as another?
Whilst I'm here, I've another problem to report...
Both front track control arm rear bushes are toast. It'd normally be the sort of job I'd enjoy getting stuck into and the parts are as cheap as chips but the warranty company are stumping up for my local garage to do it. I'm not complaining.
x 6945
Please don’t post specific issues here - this is about component fails in the Poll.
Create another post for specific issues. There are several topics on steering rack issues.
Y Cymro
x 7
Unread post by Y Cymro »
Hi Marc
Don’t know if the thread is still live as I don’t see a submit button, but would you please add a vote for EPB and another for TPS for me.
thanks!
2013 Citroen C5 Exclusive Tourer, 2.0 HDI Automatic with Techno pack
x 5672
Submit button is at the bottom of the list.
x 1939
I think if you've already voted (for something else) the button has to be reinstated by a staff member. The button isn't there for me as I've already voted for other items.
x 6945
Update
Having looked more closely at the permissions, I've made a change that should allow members to change their original votes. So if you need to add something, please do go back in and try it. Obviously, your original choices will remain, but you should be able to tick any additional boxes now.....
Y Cymro
x 7
myglaren wrote: 30 Aug 2019, 07:31 Submit button is at the bottom of the list.
Unfortunately, no submit button can be seen when viewing using an iPad.
Y Cymro
x 7
Blooming heck, now they’re there! Witchcraft!!
