C5 (X7) Component Failures /Faults / Replacements Poll
Which of the following failures/replacements (past & present) have you had on your C5 (X7)
A/C Compressor
26
4%
A/C Condenser
27
4%
Alternator
25
4%
BHI (Hydraulic Pump / Motor)
9
1%
Blown Air Module
5
1%
BSI
4
1%
Car Battery (<3 Years)
40
6%
Clutch (< 40k Miles)
5
1%
Clutch (40-80k Miles)
15
2%
Dual Mass Flywheel (<40k Miles)
3
0%
Dual Mass Flywheel (40-80k Miles)
13
2%
EGR Valve
22
4%
Electric Parking Brake
19
3%
Electric Window Regulator
48
8%
Engine Fuse Box
14
2%
Front Height Sensor
7
1%
Front Suspension Pipe
5
1%
Front Suspension Strut
54
9%
Head Unit/Audio/Sat Nav
18
3%
Heater Resistance Module
8
1%
MAF
4
1%
Manual Handbrake Cable
3
0%
Parking Sensor(s)
34
5%
Particulate Filter (FAP)
16
3%
Power Steering Pump
8
1%
Rear Height Sensor
18
3%
Rear Suspension Pipe
18
3%
Rear Suspension Strut
15
2%
Screen Wiper Motor
25
4%
Starter Motor
11
2%
Steering Rack
66
11%
Turbo
13
2%
Tyre Pressure Sensor(s)
21
3%
Vacuum Solenoid
6
1%
Total votes: 625
x 6957
C5 (X7) Component Failures /Faults / Replacements Polll
C5 X7 Saloon
C5 X7 Saloon
C5 X7 Tourer
C5 X7 Tourer
This is just an experiment to see if this is something that would be of interest to members and could be extended to other models. There would seem to be common and not so common part failures, so I thought an ongoing poll may be useful for members to record what they have had replaced or had fail on their C5 X7.
The idea being that people may get some idea of what has failed and whether this is likely to happen, or to see if there is a pattern. Some things may appear to be wear and tear items - but have been included with a mileage or time span, so could be deemed as unusual / early failure.
I appreciate there may not be as many regular X7 members / owners as there are other MK I & II C5s, so I may do a combined one for the 2 previous models if there is an interest, so please let me know if this is something you would want. Hopefully I have covered the main things.
Edit: It seems that permissions don't allow by default the changing of votes once submitted, (which makes sense), so please check through all the options first (they are in alphabetical order) before submitting. Please note that some items are referred to their formal name such as 'BHI' for Hydraulic Pump / Motor.
So past and present X7 owners, please make your mark. :P
wurlycorner
x 271
Re: C5 (X7) Component Failures /Faults / Replacements Poll
Unread post by wurlycorner »
Great idea.
I wonder if some common problems are only common to a particular variant though and that therefore makes it difficult to separate?
Iain
CX DTR T2 Safari (silver)
x 6957
That's my thinking Iain - I know for example with the steering racks that this has been a mega failure on the X7 - but almost unheard of on previous models of the C5 (or any other cars to be honest at the rate these are failing).
So I wanted to start off with the X7 variant and if there's any interest, I'll kick one off for the previous C5s - so anyone wanting this, let me know and also any specific issues affecting the earlier ones over what I've listed above and I'll put it together.
x 3566
What a great idea :)
As a thought, is there any way you can show how many unique members have voted ? Even if it's a manual monthly tally ? The results show how many votes cast, but not how many people have cast a vote.
x 6957
Unfortunately, I don't think it's possible with multiple questions Bobs. But at least we will be able to see the most common fails.
I can't remember for the life of me who mentioned a German Forum a few weeks back doing something similar - but we'll see how it goes.
x 3566
I was going to suggest adding suspension drop links into the list of failures, but then realised that's one good way to tell you've got a genuine Citroen C5. If it's failed then it's authentic Citroen - if it's still going strong then it's one of these Chinese fakes :rofl2:
DHallworth
x 167
Unread post by DHallworth »
Mine has had a few jobs done that weren't on your list...
Coolant Pipe
Coolant Bottle
LDS Tank
Hydraulic Pump
4 Spheres
Both front wishbones
Inlet manifold as the butterfly failed
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 6957
Thanks for that David.
I have the Hydraulic pump on the list (under BHI), so please do add that one.
I believe if I edit the poll now it will reset the votes cast - so I'll bear that in mind for the next one on the Pre X7 C5s
x 6957
bobins wrote: 01 Mar 2018, 19:10 What a great idea :)
I thought about that, but wear and tear got the better of me on that as then we'd have to include loads of other things. But hopefully we'll have a few more coming in over the weeks on these big expensive items.
wurlycorner
x 271
GiveMeABreak wrote: 01 Mar 2018, 19:36
Yes - annoyingly that's true, as I found out to my cost on another forum #-o
Iain
old'uns
x 127
Unread post by old'uns »
I think we all know where this poll is going.....fluid related things operated from a certain bottle under the bonnet :roll: quelle surprise
x 3566
NOT wishing to scupper this poll, but perhaps a question for fluid or steel suspension might have been enlightening ? And one for next time - what mileage band does your car fall in to ? - Realistically, would only need to be 50k bands.
Filberton
x 6
Unread post by Filberton »
Component failures from me for your library:
[The car is a 2.0 HDI manual 2008 exclusive. Manual 6 speed. Hydractive 3+]
Generally a great car and the faults are no worse than any other and generally less than I've had on other cars.
All four discs were declared badly worn and failure on it's first ever MOT (3 years and 60,000 miles) but they were changed using pattern parts (non-Citroen) from EuroCar Parts and no problems since (now 149,000 miles)
From the very start the front left tyre always wears prematurely on the outside edge (not inside edge). Tracking, tyre pressures bushes checked and different makes of tyre all do the same. I suspect it is the camber angle but no garage has ever found the fault. Not major as the outside 30mm goes bald only when 2mm of tread left. (no sign of having been "kerbed" )
Steering rack, yup...it failed at 120,000 miles (but cheaper fix by replacing with a refurbished part in exchange by my Indie)
High Pressure input pipe to the steering rack failed (reported as fatigue-like by my Indie garage)
LDS tank split (but I think that was a garage hanging all four wheels without first setting the car in top suspension)
Front right suspension strut leak (but not surprising at 130,000 miles
Here is an odd one
For the past 30,000 miles hard acceleration in 5th there it is like a slipping clutch but no burning smell. I have wondered about the dual mass fly-wheel but there is no noise and slight back off and it stops or if I drop it a cog or two and I can accelerate without issue. Doesn't seem to be getting worse.
Front side lights (xenon on the mains) kept blowing but since I replaced them with LEDs they have been fine.
The Xenon steerable lights often throw up a gremlin (flashing green lamp on dash and they stop swivelling but it usually self clears after about 5 minutes so not a problem)
other than that just routine maintenance. (tyres, filters, wiper blades). Still original exhaust and tyres.
I am told the 1.6 model blows its turbo due to oil starvation but the 2.0 seems ok
Hope that all helps your library. Right, off to start the C3 list :-) :-D
Mike
Current: C5 X7 Exclusive 2.0 HDI Manual (2008)
C3 Puretech 1.2 Feel (2017)
Previous: Citroen C5 mk1 2.0 HDI,
Peugeots 407, 406, 406,205,309, 306 Meridian, 306 L, Peugeot 207L 1.4 manual (2003)
x 3566
Filberton wrote: 01 Mar 2018, 20:26
Here is an odd one
Mike
"They all do that, Sir. It'll ride up with wear" :)
That'll be the self-adjusting clutch failing to live up to is name. It'll be slipping in 5th / acceleration as that'll be around the greatest loading on it. You can try 'shocking' it into adjusting - sometimes it works sometimes it doesn't. Basically - getting it to adjust revolves around a lot of revs and 'shocking' the clutch... but it's not that easy as the clutch pedal seems to be damped. Try either driving along at about 50, then pressing the clutch pedal in, rev it and dump the clutch. Repeat until fade, as they used to say :wink: Alternatively, drive along - preferably downhill - in 2nd or 3rd or 4th at high revs, press the clutch pedal down, coast in gear with foot off the accelerator, dump the clutch pedal. Repeat until fade :wink: Or.... just rev the nuts off of it in 3rd or 4th or 5th :wink: As I say - it may work, or may not.
Mine has been randomly slipping for about 15-20k in 5th and 6th under load. Sometimes it adjusts up, sometimes it doesn't. :?
x 1942
Unread post by Paul-R »
Added my bit, clicked vote and then noticed that there was an option for the TPMS valve. Can you add one more vote to that please Marc?
