BSI reset C5X7
morto
BSI reset C5X7
Unread post by morto »
hello all there seems to be a lot of different ways to do a BSI reset but what's the OEM correct method of doing this
thanks
Andy
2002 2.2hdi C5
x 6955
Re: BSI reset C5X7
I put together a new guide here, based on the different reasons to do one - Battery Connect / Disconnect or BSI Reset and to account for any work need to be done in between the procedures. This was for the very reason you mentioned that there are versions that have been added to and amended. I have done this because the other general guides were not as specific and did not explain the reasons why and importance of the procedure at various steps.
BSI Reset / Battery Disconnect & Connect
This is derived from several of the manufacturer versions across models which themselves do change.
morto
Re: BSI reset C5X7
Thank you Marc
2002 2.2hdi C5
leithant
x 9
Re: BSI reset C5X7
Unread post by leithant »
What I have always wondered is, is there any confirmation that the reset has actually happened, like a beep or anything?
06 Citroen C5 Estate 2.2 Hdi Auto
95 Peugeot 306 S16
95 Silver Xantia VSX - now deceased :-(
x 6955
Re: BSI reset C5X7
No. It is the ECUs that write their data, are then powered down, left to sleep, then are reinitialised. There are no beeps whistles or bongs. You may have in excess of 25-30 ECUs on your vehicle.
You may hear some whirring, but that is only electro valves opening and closing equipment like the EGR after a period of time has elapsed after the ignition is switched off.
It’s another reason why the timings are important to follow- in order to allow all the kit to shut down properly, and not to open doors or press switches, or leave keys in the ignition, as these cause triggering events that can wake up the ECUs in anticipation of you driving off, for example.
x 1938
Re: BSI reset C5X7
Marc, could I suggest you add on the routine for when you have a keyless system? I know you posted it up in a separate query recently but I cannot for the life of me find it.
x 6955
Re: BSI reset C5X7
I remember posting a bit up about how to access ignition only with Stop Start system - is that what you are referring to Paul?
x 1938
Re: BSI reset C5X7
Could be if it includes how to do the BSI reset if you have a keyless system?
x 6955
Re: BSI reset C5X7
I'll have a look tomorrow Paul and see if I can cobble something together.
x 1938
Re: BSI reset C5X7
Ta. It's not for me as I have a proper key!
x 6955
Re: BSI reset C5X7
Amen to those. Keyless systems are one of those 2 steps forward, 10 back moments as far as I'm concerned.
