DS3 waterpump tube fitting?
Viitonen
(Donor 2022)
x 11
Unread post by Viitonen »
Advice needed!
I’m repairing my daughter’s 2012 DS3 120VTi.
There is a pipe/tube between the waterpump and thermostate case. The Citroen part number for it is 1351VF.
My question is the bolts/clips/fittings of this pipe. There are three holes, but that pipe was not fit with anything (someone must have removed it earlier).
Does anyone know what kind of bolts etc are needed there? The space is extremely small, so I cannot look there to see what is needed.
Thank you!
x 6957
Re: DS3 waterpump tube fitting?
Can you post up your VIN so we can get the right specs., as there are 3 variations of the 1.2 VTi and none of them have that part number.....
Viitonen
(Donor 2022)
x 11
Unfortunately I’m not near that car before friday, when I’m supposed to fix it.
I must have said it oddly, the car is not 1.2 liter, it is 1,6 liter VTi120 hp engine.
It is this pipe: (sorry for copying someone’s eBay auction!)
https://www.ebay.co.uk/p/Peugeot-CITROE ... 1416312318
x 6957
Ok, we got there in the end!
The clips are 13 & 14 in the diagram and the pipe is part 3.
Viitonen
(Donor 2022)
x 11
Thanks Marc, yes, the part is number 3 in that pic, but in this photo 13 is a clip and 14 is an O-ring. I am not looking for them.
If you look the eBay photo, you see that there are three holes in that pipe. I’m looking for what goes into those holes.
x 6957
I think you'll find that this part is used on about 30 vehicles at least, within the PSA range and are attached differently - so I wouldn't worry about it. If there was a fixing point it would show it.
x 1454
Unread post by xantia_v6 »
I would not be surprised if the holes are not used. This random picture of a THP engine indicates that the holes are floating in free space:
The pip is in no danger of escaping, as it is firmly wedged between the pump and the thermostat housing.
x 6957
Yes, that's what I think too Mike - I did find an example of the same part on one diagram showing a clip being used - but not on a DS3.
x 1454
Here is another picture from the net, showing the thermostat housing and the clip:
Viitonen
(Donor 2022)
x 11
Oh, great! Thank you guys, now I don’t need to worry about those holes since they are not in use 👍
