Ok im a tad fed up today, part arrived and I fitted it easily , have calibrated it with Lexia and very hit and mis, I started with 10 fault codes on the ESP81 and have got them down to 5, and at one stage down to 4 after getting the ABS light out but this was short lived with the ABS coming back on after 5 mins still got both ESP,ABS, lights on ,, ive also put a new battery in just in case , so after doing the calibration on Lexia it says success and I clear the codes.. unsure what to do now
BMF : Built-in Systems Interface (BSI)
Response data
R61809664058780002C96640588800501FFFF084052114799
R61B1940C04B02160000220A1AE0200
R61BA1800000000000000
State of the ECU: BSI
Reference 1 : 9664058780
Reference 2 :
Faults present : 2
F5FF : Unexpected re-initialisation fault coming from the BSI.
Characterisation : not characterised
Status :
Variables associated with the fault
FA58 : Study fault : Do not take it into account
Status :
AAS : parking aid
Response data
R6180965601968000039663821680012DFF05054056377799
State of the ECU: AAS
Reference 1 : 9663821680
Reference 2 :
Faults present : 0
ABRASR : ABS/traction control
Response data
R6180966573028000039665730280FFFFFFFF0001FFFFFF00
State of the ECU: ESP81
Reference 1 : 9665730280
Reference 2 :
Faults present : 5
C139B : gyrometer accelerometer sensor signal fault
Characterisation : Short circuit to positive or short circuit to earth or open circuit
Status : Permanent
vehicle speed : 0 kph
Front LH wheel speed : 0 kph
Front RH wheel speed : 0 kph
Rear LH wheel speed : 0 kph
Rear RH wheel speed : 0 kph
EBA regulation : deactivated
EBD regulation : deactivated
Anti-slip regulation with action on brakes (BASR) : deactivated
Anti-Slip with action on engine torque disconnected (ASR/ESR) : deactivated
Anti-engine brake regulation (MSR) : deactivated
Anti-Slip regulation with action on engine torque (ASR) : deactivated
Electronic Stability Program (ESP) regulation : deactivated
ABS regulation : deactivated
Recirculation pump activated : No
Electric parking brake status : On
Status of the "assisted holding" function : No holding
Braking status : No braking in progress
Yaw angle speed : 000 °/s
transverse acceleration : -00.3 m/s²
Steering wheel angle : 151.3 degrees
Distance travelled since last time ignition switched on : 0.0 km
supply voltage : 12.2 V
Braking pressure : 00.0 bars
status of the ECU : Main
longitudinal acceleration : 0.00 m/s²
C1502 : longitudinal acceleration sensor signal fault.
Characterisation : Internal
Status : Permanent
Status of the "assisted holding" function : Fault
Yaw angle speed : Value invalid °/s
transverse acceleration : Value invalid m/s²
supply voltage : 12.1 V
C1315 : lateral acceleration sensor signal fault
Status : Permanent
C1310 : yaw sensor signal fault
Status : Permanent
U1325 : Fault: no communication with gyroscope accelerometer sensor.
Characterisation : no signal
Status : Temporary
supply voltage : 10.0 V
ABS/ESR
morto
Re: ABS/ESR
this is when I got it to 4 fault codes
ECU : ESP81
Response data
R5700
Fault codes
BACK_BTN
Date and time : 2019-03-07 14:42:05
pack repair
Date and time : 2019-03-07 14:42:07
Spare part
Date and time : 2019-03-07 14:42:12
Longitudinal acceleration sensor calibration
Date and time : 2019-03-07 14:42:16
OK_BTN
Date and time : 2019-03-07 14:42:19
OK_BTN
Date and time : 2019-03-07 14:43:27
OK_BTN
Date and time : 2019-03-07 14:43:29
OK_BTN
Date and time : 2019-03-07 14:43:37
BACK_BTN
Date and time : 2019-03-07 14:43:42
reading and clearing of faults
Date and time : 2019-03-07 14:43:44
Reading fault codes
Date and time : 2019-03-07 14:44:04
ECU : ESP81
Response data
Fault codes
characterisation of the fault. : no signal
Status . : Permanent
from . : local .
characterisation of the fault. : Internal
from . : local .
from . : local .
from . : local .
ECU : ESP81
Response data
R5700
Fault codes
BACK_BTN
pack repair
Spare part
OK_BTN
OK_BTN
OK_BTN
OK_BTN
BACK_BTN
Reading fault codes
ECU : ESP81
Response data
Fault codes
from . : local .
from . : local .
from . : local .
from . : local .
2002 2.2hdi C5
- x 6963
Re: ABS/ESR
Well it's not happy about something. Have you checked all the connections on the ESP/ABS ECU? - all these systems feed back into this ECU - if there is a faulty wiring connection or the connector is loose, that could be a cause. The fact that the same messages are appearing intermittently on and off suggest either the faults are remaining, or there is a connection problem on the data network, or electrical connections.
morto
Re: ABS/ESR
Thank you Marc , I did think maybe connections ive looked at all the wires when they were out and all looked like brand new, I might just have bad luck and maybe the second unit ive bought is faulty , its going to be a tuff one , I don't think there is any way you can test these units
Thank Andy
Thank Andy
2002 2.2hdi C5
- x 6963
Re: ABS/ESR
Check inside the actual plug connectors of the ECUs. Look to make sure the pins are visible and making contact. It is not unknown for a wire to be under strain and pull a pin out or for the wire to have a break. Check the connections near the engine fusebox. Have you got any third party / after market electrical accessories wired in to the car's electrical system anywhere, or have you spliced into or made any electrical wiring connections?
morto
Re: ABS/ESR
quick update on this I thought I would run the car for a few days just so the ECU can gather some information, now the electronic brake fault sometimes goes out and works correctly and then returns again, and ive gone through Lexia again and done everything it tells me to do but what I cant work out is after doing all calibration Lexia says success it then tells me to delete the fault codes and at that stage I think all is good but then all fault codes come back , the bit I don't get it when it says success I would of thought it would say it cant communicate with it? I know this is a tad over the odds but ive bought another second hand one and just maybe the other one I bought is faulty its just worth a chance if thats no good I will have to seek professional advice at silly money.. Marc I will check all pins and the car does not have anything external on it.. also do you think its worth changing the brake switch sensor?
Andy
Andy
2002 2.2hdi C5
morto
Re: ABS/ESR
another update, ive tried another ESP81 and still get loads of faults so I don't think the problem lies with that, I have managed to calibrate the steering wheel sensor , and there is no faults on the FSE so does that mean that then EBC is ok?
can anyone help were I might look for the Gyrometer accelerator sensor signal fault.. it says
SHORT CIRCUIT TO POSITIVE OR SHORT CIRCUIT TO EARTH OR OPEN CIRCUIT
I just don't know were to look? then yesterday it showed no faults EBC worked as in automatic mode until I switched it off then back on ..
thanks
Andy
thanks
Andy
2002 2.2hdi C5
- x 6963
Re: ABS/ESR
The intermittentcy of the problem is making it difficult to pin down unfortunately. Like I mentioned earlier, one fault i.e. in the ESP system is enough to cause the handbrake automatic functions to be deactivated, cruise control etc. so it's a matter of narrowing down the main fault without replacing expensive parts unnecessarily.
morto
Re: ABS/ESR
Update on this is ive put a new brake switch on today and before Lexia said Brake signal fault, then after no Fault so even thou the brake lights worked there was still an issue somewhere but sadly my issue with the ESP/ASR is still there its driving me nutsss..please zoom in
2002 2.2hdi C5
- x 3283
Re: ABS/ESR
There may be TWO switches in the casing (there is on my C5 Mk1). The main pedal switch (which is a 'push to make' type) is for the brake lights, while the redundant pedal switch (a 'push to break' type) is to disconnect the cruise control (if the stalk is added and the cruise control system is set up). This assumes the brake switch system works in the same way as on MY C5.
morto
Re: ABS/ESR
Another one that came up today that I haven't seen before was Unexpected re-initialisation fault coming from the BSI, please zoom in
2002 2.2hdi C5
morto
Re: ABS/ESR
Many thanks pal, the cruise has always worked fine, a few things that ive read about my ESP/ASR issue is, Fuse box, ABS complete system, BSI, and the main ECU.. at the end of the day the cars not worth a great deal .. im proper fed up as even with Lexia it all comes down to maybe taking each part out and getting them checked.. has anyone else had this issue and fixed it
thanks
Andy
thanks
Andy
2002 2.2hdi C5
- x 6963
Re: ABS/ESR
Which replacement brake switch did you get? Did you get the one with the loom, and secondly, did you read and clear all the faults?
morto
Re: ABS/ESR
Hi Marc I got the one you gave me the link for , it had a separate wiring loom
http://www.eurocarcare.net/switches-rel ... -loom.html
I also read and cleared all faults
2002 2.2hdi C5
morto
Re: ABS/ESR
and another new one was Fault U2119 electric parking brake automatic release function wake up status word reception problem... I feel overwhelmed and feel like the car is shutting down
2002 2.2hdi C5
