XU7JP4 engine Injector problems
40075trip
Unread post by 40075trip »
Hello Everyone!
I have Citroen xsara 1.8 v16 XU7JP4 engine code with manual transmission, 1998, did 213,000.
The car maintained only with original parts, oil change every 8k, I really take care of it!
Lately my car isn't running good, the throttle response is a bit slow, high fuel consumption and while driving the car struggles to go higher than 3000-3200 rpm.
My mechanic connected the car to the computer and everything was good, after checking everything he said that the fuel injectors are a bit clogged .
I tried to find new injectors but there is no one that sells new once. even tecdoc can't find my injectors.
The part number on the injector is D7132MA . Do you know where can i find new injectors or find any other OEM brand that sells them.
Thank you!
Isaac Mor
Will Go To a Journey Around The World With My Xsara Next Year. So far working hard :P 8-)
x 6956
Re: XU7JP4 engine Injector problems
Pop your VIN up and we can get the official part numbers.
40075trip
VF7**************[VIN obfuscated, can be read by forum staff] Here is the VIN number
Isaac Mor
x 6956
The part was 1984A2 and is no longer available from Citroen.
Search 'Citroen 1984A2' in your browser and you should come up with some second hand ones.
Here's a UK parts supplier with some:
https://www.proxyparts.com/car-parts-st ... njection)/
40075trip
It's a bit dangerous and risky to buy second hand. I found Bosch injectors 0280155809 TecDoc shows that this injector fits Citroen Xantia with the same engine that i have. XU7JP4. What do you think about that? Should I buy it? It is probably the same injector, isn't it>?
Isaac Mor
x 6956
These are the PSA Injector part numbers for S1 & S2 XU7JP4 engines:
Xantia S1 (XU7JP4) Bosch - 198493
Xantia S1 (XU7JP4 LPG and Unleaded) - 1984A9
Xantia S1 (XU7JP4) Sagem - 1984A2
Xantia S2 (XU7JP4) Carburettor Pump Injector, EEC 2000 Depoll engine) - 1984C5
Xantia S2 (XU7JP4) EEC 95 Depoll Engine & Automatic Bosch - 198493
Xantia S2 (XU7JP4) EEC 95 Depoll Engine & Manual Sagem - 1984A2
Xantia S2 (XU7JP4 LPG and Unleaded) 1984A8
