C4 Heater/AC not working
Lia3110
Hi everyone,
I seen in an old tread that people were having similar issues but wanted to get some advice specific to my problem.
Ok so, I have a 2005 Citroen C4 and the other morning I started the car and the heater/AC just didn't come on. But it was working fine the night before. The rear window demist still works. The lights come on and everything on the screen works fine.
I have changed fuse 11 under the bonnet and still nothing. When you put it on you can hear a buzzing noise as if it's trying to start and clicking noises when I press the buttons and fluid is fine as well.
Any help would be much appreciated. And if you need any more info just let me know.
Leanne
Leanne
- x 6945
Re: C4 Heater/AC not working
Hi and welcome Leanne.
It's a common problem and seems to be moisture getting into the bearings. These units have a 'slow start' feature that gradually ramp up the power, but it can also be insufficient power to free the bearings when starting off at the slower speed.
Others have temporarily bypassed the blower control module so that it gets full power to give it some welly to start it off.
You'll find this will likely happen intermittently.
Paul has posted up a some info - when I find it I'll link to it here.
Here you go:
viewtopic.php?f=3&t=61293&hilit=bearing ... 30#p592581
Here you go:
Lia3110
great thanks, i shall go and have a read and see what i can do.
I'm not sure if i was clear enough before, when i said you can hear a buzzing noise its very faint and goes off within seconds, it is the same kind of noise as you would get if you were inserting a CD into the CD player and it happens when i press the AC button or if i turn up to power of the fan from min to max. It stays the same even if the car has ran for some time.
Anyway thanks again hopefully get something sorted, i really appreciate the help.
- x 6945
Those noises could be just the air distribution or mixing flaps moving about to adjust the air flow or air mixing to get to the set temperature.
Lia3110
Thank, I have been on the link and had a wee look and I can see that bridging 2 wires has been suggested but I'm not quite following how I would do this and which wires it would be.
Would you be able to go into a bit more detail?
admiral51
- (Donor 2026)
- x 391
Hi Lia3110
Assuming yours is the same as mine then if you can remove the plug then bridging the wires is easy.
download/file.php?id=11903&mode=view
That is a picture of the plug showing the 4 wires.
With the plug unplugged put a wire across the Black and Green/Yellow wire pins, start the car and the try the blower, fingers crossed it works.
Switch off, remove bridging wire and plug back in.
Stat car, try blower, if all okay put trim back in place
- x 6945
You'll need to remove the front passenger well side trim with a trim tool.
The Blower control module on your car is here:
... and it looks like this:
There is a connector on the end and the module is removed with an anti -clockwise turn
Lia3110
OK thank you both for the help, i shall try this today if i get a chance and i will get back to you as soon as i have any results.
Really appreciate the help
Leanne
Leanne
admiral51
- (Donor 2026)
- x 391
The module itself is awkward to remove and will involve scraped skin and swear words so if you can unplug the plug so much the better
OnlinePaul-R
- x 1940
Chicken and egg. I found the plug a real swine to take off and found it easier (relatively speaking) to unscrew the control unit and then take the plug out.admiral51 wrote: 27 Jan 2019, 14:58The module itself is awkward to remove and will involve scraped skin and swear words so if you can unplug the plug so much the better
Make of that what you will!
admiral51
- (Donor 2026)
- x 391
I still have all my skin on my hands and to be fair it is now no longer in my custody
OnlinePaul-R
- x 1940
Once you have the hang of it knuckle skin remains unbroken each time you take it out (oo-err missus).
Lia3110
Hi everyone i finally got around to getting it sorted, it turns out it was the under bonnet fuse box that was the issue and i had to replace it.
Thanks so much for all your help and suggestions
Leanne
Leanne
OnlinePaul-R
- x 1940
Wow. How did you trace the problem to the fuse box?
snawheed
Iv got same problem, no heater blower, checked fuses changed motor, changed resistor, changed control panel, looks like il have to go down the "bridging" option.
C4 2.0 hdi vds
C4 2.0 hdi vds
