Front Exhaust Pipe - 53 plate Xsara Picasso SX
TheOtherPablo
Unread post by TheOtherPablo »
Good evening everyone,
So the Picasso experience has another interesting chapter.
On the way home this evening, I completely lost power and the car sounded like it turned into a tractor. MiL light and Engine Fault Warning on the screen. Decided to crawl it the 5 or so miles home.
Looks like the front exhaust has dropped explaining the tractor sounds and I'm getting a P1336 error code through the OBD
Would anybody please be kind enough to have a diagram of the complete exhaust system??
Cheers in advance for any help
This is fun!
x 1485
Re: Front Exhaust Pipe - 53 plate Xsara Picasso SX
You can see a diagram on the Bosal catalogue: http://www.bosal.com/en/catalog/exhaust ... 2/SYS01393
Looks like the front section flexi is also the cat, so it won't be cheap....
4um
Unread post by 4um »
Image attached.
moizeau
x 429
Unread post by moizeau »
Wouldn't mind betting it's cracked the weld on the flexi, it can be welded if that's the case.
Pete
TheOtherPablo
Cheers both, very helpful, greatly appreciated. We're going to take a look later this morning, hopefully this inclement weather will improve in the meantime
