leaking 1.9d xantia diesel pump
[email protected]
Unread post by [email protected] »
hi guys
ive just noticed today that on the top of the diesel pump on my 94 1.9d xantia is leaking around the top of the accelerator lever on the pump does this mean i need a new pump or is there any seals there wich i can replace myself as i have noticed the top of the pump can be removed
any advice will
be apprecated
cheers
pete........................
tonespeed1999
Unread post by tonespeed1999 »
they can be replaced.
i would strongly advise letting a diesel specialist doing it.
very fiddlely to do!
[email protected]
hi tonespeed
Thanks for the response just what makes them so fiddly to do as im quite experianced at doing cars. but ive never worked on a diesel
tonespeed1999
you just need to note the position of the throttle spindal when you remove the pump top.allow your self a couple of hours to be on the safe side.
[email protected]
hello agian tonespeed
Thanks for the info i will be abile to do that ok. this is all good news to me as i thought i was going to have to replace the complete pump and that looks quite an involved job anyway thanks agian and ill keep you posted as to how i get on.
thanks
pete........[:)]
tonespeed1999
hopefully you will just get away with a seal.
mrbump
Unread post by mrbump »
hi pete,
i had the same problem on my 405's pump after I changed the engine. Didnt notice it until it was in...
I dont know how bad yours is, but if you remove the 10mm nut on the throttle spindle and turn it back a bit with a flat blade screwdriver, then tighten it up again you should be able to tighten it down enough to stop the leak without a seal. Its tricky though as if you go too far you will hear the idle raise and you will have to start again.
mines been cool for over 15000 miles now though and it was really squirting out!
In fact from memory, the lucas guy told me it was a non repaceable bush, and that it was wear on the spindle itself, hence why i tried so hard!
Cheers
[email protected]
hi mrbump
thanks for the info ill try that first, do you mean move the spindle or the lever back a bit ? how bad is it well you can see diesel just trickleing out when the engine is idling i hav,nt tried anything as yet and tonespeed says there is a seal in there so im going to have to check this out for myself if the tightening dos,nt work. anything
else to add to this just let me know
thanks agian guys
pete.................................
ps ill keep you posted
oilyspanner
Unread post by oilyspanner »
Theres a kit for roto pumps consisting of a bush and an o ring, easy enough to change, theres more than likely one for Bosch too, just clean everything off before you start.
Stewart
mrbump
Hi,
For the bosch pump. Take off the locknut so you can move the arm seperately of the spindle (the rod sticking out of the top of the pump with the screwdriven top). So that the splines are not contacting, you dont have to remove it completely. Then turn the spindle back a bit with a flat blade screwdriver. You will notice the idle has dropped. Then put the arm back on and tighten up the 10mm nut. It will pull up the spindle tighter against the seal, but make sure you dont let it turn too far or you will raise the idle. It may take a few attempts to get it spot on.
HTH
[email protected]
hi agian
thanks agian mrbump my diesel pump is a lucas does the same apply? i have,nt actully got down to the job yet but i will have more time at the weekend. and oily spanner is that kit readly avalable as not had time yet to get to a specalist
thanks agian guys
pete................... [:)]
oilyspanner
Yes I got it from a local diesel specialist for about £7 at the time, the kit was a bush, a new spindle and an o ring, remove pump top, drift out old bush drift in new one, refit with new spindle and o ring and no diesel fuel dribbling down the front of the engine, good luck sourcing the parts.
Stewart
[email protected]
hi stewart
Thanks for that im going down to a diesel specialist tommorrow on your advice so hopefully he will have the right kit and i can get it sorted over the weekend sound,s quite an easy job abit a bit fiddly but at least it will save keep losing diesel down the front of engine which is costing me money
thanks agian
ill keep you posted how i get on
pete................[:)]
[email protected]
hi guys
Thanks for your info well ive just spent the afternoon replacing those seals and i was surprised just how small they are
took off the levers removed the top of the pump and replaced the seals on the spindles and as tonespeed said a very fiddly job anyway ive done it now and the leak is gone [:D] thanks stewart for your help it was that which helped me a great deal and also mrbump for your help. i went to one specilist and he was going to charge me £60 for doing the job and he said he would,nt sell me the the kit as people make a right mess of it! anyway i rang somewhere else who did sell me the kit for £5 now ive done the job and £55 better off [:D] and bit more experance all in all the job took me about three hours
anyway thanks agian
pete.................. [:)]
oilyspanner
Well done Pete
Stewart
