Alarm unavailable
Jlm19900
Alarm unavailable
Unread post by Jlm19900 »
Hi, my relay van says on the dash alarm unavailable when I start it up, just wondered if anyone would know why this is? I tried testing it by locking the van with key fob and then opening with just the key, all the indicators flash but no sound. I haven’t had the van too long and it could of been there since I bought it I just didn’t notice. Any ideas anyone? Cheers.
x 6956
Re: Alarm unavailable
Either the siren has been disabled or disconnected physically or via configuration - the rapid indicator flashing indicates a triggering of the alarm, but you're just not getting the siren going off. Lock with fob - unlock with fob fine, but lock with fob and unlock with key - triggers siren normally and flashing of indicators which is as it should be - so somebody may have nobbled it.
If you want to check the connections, I'll need your VIN posted here (will be masked automatically).
Jlm19900
Yea that be great thank you VF7**************[VIN obfuscated, can be read by forum staff]
x 6956
Ok, so after the ignition is switched on, in the case of an incorrect alarm system diagnostic test, the instrument panel receives a message containing the fault detected from the built-in systems interface.
The coded engine immobiliser warning lamp comes on, - on the comfort version instrument panel, a message is displayed on the dot matrix screen ("alarm not available" in the case of a failure of the alarm system, " vehicle intrusion detected" in the case of triggering of the alarm system).
So I suspect that in the case of the system on this Relay, there is a defective component, as the Alarm module can't be configured using the diagnostic tools.
Components of the System:
Location of the Siren:
So hard to say whether the Siren is faulty or the ECU itself
Jlm19900
Thanks Marc, I will try and test the siren first. Do you have any of these diagrams for the radio antenna, just because my signal is very poor and only pick up radio stations in the city centre
x 6956
Here's the aerial on your Relay. note that you only have items (1), (2), (5), (11), (13), (14) & (20)
(20) is the Aerial amplifier.
To get to the aerial the sun visor needs to come off and part of the headlining!
van ordinaire
(Donor 2017)
x 402
Always delighted to find the alarm on any car I've got doesn't work. Another useless complication AND downright antisocial. They should be banned! Rejoice!
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
Jeep XJ Cherokees x 3 :?
'96 Cadillac Eldorado
'99 Cadillac STS :|
x 5672
My C5 isn't fitted with one, only an immobiliser :)
x 6956
When you decide to join the modern age Van, all its delights will be ready for you in all their glory.
van ordinaire
(Donor 2017)
x 402
Oh the irony, in the middle of revelling in being the Luddite of the group - my internet connection failed (probably because it's snowing!)
Have absolutely no intention of joining the "modern age" which has very little to commend it all (unless you are a tecno-geek, of course) but it has pushed upon us endless bits of frippary which are very expensive, do nothing useful & are alarmingly unreliable. Many years ago I learned that if I was seduced by something pretty, fun or even remotely useful, the answer to "do I need it?" was a resounding NO! Of course it cannot be said I apply the same logic to buying cars
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
'99 Cadillac STS :|
x 6956
Ver good 😂
Oh well, back to bean cans and string Van.
moizeau
x 429
Unread post by moizeau »
I'll send you a PM Van, the carrier pigeon should be with you shortly.
Pete
x 6956
van ordinaire wrote: 22 Jan 2019, 20:47 Oh the irony, in the middle of revelling in being the Luddite of the group - my internet connection failed (probably because it's snowing!)
x 1938
van ordinaire wrote: 22 Jan 2019, 20:47Many years ago I learned that if I was seduced by something pretty, fun or even remotely useful, the answer to "do I need it?" was a resounding NO!
Does that include women in general and the wife in particular?
x 2941
myglaren wrote: 20 Jan 2019, 13:00 My C5 isn't fitted with one, only an immobiliser :)
My C5 has one, it screams at me occasionally (If we're still talking about alarms.)
