Citroen C2 locking issue
- x 6945
Re: Citroen C2 locking issue
Have a look around Lexia whilst there (with caution obviously) to see if you can see what it is or isn't doing
tomjyoutwit
- x 5
Afternoon Marc, tried it but there is a fault on switch underneath the steering wheel.
- x 6945
Ok, so the comms unit is faulty then - is that what Lexia indicated? Let me know iof you want the part number for that.
tomjyoutwit
- x 5
6160C0?
Just spoken to the hub, they would have to order it in, but it's only £5.90 so it's not too bad.
- x 6945
That's the Transponder aerial - not the Comms Unit - completely different. But correct part if you are getting a new aerial and I think I suggested earlier that that was a cheap enough option to try first.
The comms unit is the control unit that handles amongst other things the info from the transponder aerial and passes this to the BSI and back again.
tomjyoutwit
- x 5
I've replaced the transponder coil before but I think when it worked itself loose it strained the wire. How much would a new comms unit be?
tomjyoutwit
- x 5
Marc, would you send a picture of the comms unit please as someone local to me is breaking a C2!
- x 6945
The picture won’t help Tom, there are 100s of Comms units, and they all look similar. Putting the wrong one in can cause additional ones problems. I will get you the part number a little later when I’m back on the Hal9000
- x 3296
So long as he opens the pod bay doors for you, Marc!
- x 5672
I wonder what Malcolm would have made of that!
- x 6945
Was on the tablet (not the pills) when I wrote that - and watching a movie, so sorry if that came out a bit wrong!
- x 6945
Here you go, if you think you need a replacement:
Part number 6239ZX. One here for £90, but as I said, it MUST be the correct part. The manufacturer's part will be on the inside of the unit itself and begin 96 or 98.
https://peugeotpartsforsale.com/index.p ... -no-6239zx
tomjyoutwit
- x 5
So my Chinese key arrived, I've purchased a new transponder aerial and central locking and the immobiliser now work!
But for how long I wonder!
- x 6945
Well done! Just don’t go and drop it down the drain! You might want to consider another fob as a backup
tomjyoutwit
- x 5
I’m going to program the transponder only key to get me out of the brown stuff if I need it!
