Citroen C2 locking issue
x 6957
Re: Citroen C2 locking issue
Have a look around Lexia whilst there (with caution obviously) to see if you can see what it is or isn't doing
tomjyoutwit
x 5
Unread post by tomjyoutwit »
Afternoon Marc, tried it but there is a fault on switch underneath the steering wheel.
x 6957
Ok, so the comms unit is faulty then - is that what Lexia indicated? Let me know iof you want the part number for that.
tomjyoutwit
x 5
6160C0?
Just spoken to the hub, they would have to order it in, but it's only £5.90 so it's not too bad.
x 6957
That's the Transponder aerial - not the Comms Unit - completely different. But correct part if you are getting a new aerial and I think I suggested earlier that that was a cheap enough option to try first. :wink:
The comms unit is the control unit that handles amongst other things the info from the transponder aerial and passes this to the BSI and back again.
tomjyoutwit
x 5
I've replaced the transponder coil before but I think when it worked itself loose it strained the wire. How much would a new comms unit be?
tomjyoutwit
x 5
Marc, would you send a picture of the comms unit please as someone local to me is breaking a C2!
x 6957
The picture won’t help Tom, there are 100s of Comms units, and they all look similar. Putting the wrong one in can cause additional ones problems. I will get you the part number a little later when I’m back on the Hal9000
x 3306
So long as he opens the pod bay doors for you, Marc! :D
x 5674
I wonder what Malcolm would have made of that!
:taz: :clap: :bouncy: :bl: :lolhit: :luv: :pp: :dom: :yeah: :yikes: :teabag:
x 6957
Was on the tablet (not the pills) when I wrote that - and watching a movie, so sorry if that came out a bit wrong! :-D
x 6957
Here you go, if you think you need a replacement:
Part number 6239ZX. One here for £90, but as I said, it MUST be the correct part. The manufacturer's part will be on the inside of the unit itself and begin 96 or 98.
https://peugeotpartsforsale.com/index.p ... -no-6239zx
tomjyoutwit
x 5
So my Chinese key arrived, I've purchased a new transponder aerial and central locking and the immobiliser now work!
But for how long I wonder!
x 6957
Well done! Just don’t go and drop it down the drain! You might want to consider another fob as a backup 👌
tomjyoutwit
x 5
I’m going to program the transponder only key to get me out of the brown stuff if I need it!
