c4 tailgate issue
laurence2410
c4 tailgate issue
Unread post by laurence2410 »
hi everyone, i have an issue with my tailgate it wont open and needs replacing but there are so many to pick from on the internet i am strugling to identify the correct part. my vehicle is a 60 plate citroen c4 grand picasso 1.6 hdi vtr+. any links or advice would be massively appreciated. many thanks.
x 5651
Re: c4 tailgate issue
Welcome Laurence!
Stick your VIN here and someone with access to Service Citroen will narrow down the options for you.
laurence2410
i dont really no the vin mate?? i have reg number but didnt really want to post that
x 6954
The VIN is on the outside windscreen, lower corner passenger side, beginning VF. Or post your Reg in a private message. The VIN is masked when submitted here automatically, but don’t send the VIN in PM or I can’t see it.
I need the VIN or the REG to ensure we get the exact part for your car.
laurence2410
ok mate thanks, i sent you a pm.
x 6954
Nothing arrived,,,, make sure you click on the ‘Contact’ icon to the left under my avatar, as the spellings are case sensitive.
laurence2410
did it again using the method you suggested. fingers crossed
x 6954
Ok, got that leave it with me.
x 6954
Here you go:
The official Tailgate part is 8701W5.
Obviously there are various parts available separately, but if you are replacing the whole thing that is the part for item (1) on the diagram.
x 1480
Unlikely you need to replace the entire tailgate. What usually happens to these is that the tiny plastic pins break off the handle and it no longer operates the micro switch to activate the release mech. The switch is available separately for about £30 - although there are 2 types of microswitch fitted - the handle comes with one, and if you have the other type then you have to buy that as well :evil: .
You can change over the microswitch if it's not broken (another common failure point) - this is what I did on mine.
Edit: Actually the lock is now £48.26 from Citroen, but there are loads on e-bay cheaper than this.
TomK
Unread post by TomK »
Hi, I've had an issue with my tailgate but bought the square micro switch instead of the round. Is it possible to use this or do I need to buy the round one?
x 1480
IIRC the connector is a different shape between the two switches, but it's only a simple contactor, so if you've got the wrong one you will either need to buy the right one, or butcher the wiring to connect it. The switch is not that expensive (in absolute terms, it is for what it is!) so it might be better just to get the right one.
TomK
Thanks Richard, I bought the correct one on eBay €20
Pianar
New User
Unread post by Pianar »
Hi. Is the difference between needing the round ended switch and the square type just whether your car has an opening window or a sealed one?
My car has an opening one so I think I need the square type.
Could you confirm if this is true please?
Many thanks.
