Esp/asr system faulty on C5
x 6960
Re: Esp/asr system faulty on C5
I really wouldn't bother with that one - far too cheap and probably inferior quality. If you read through that thread, cleaning it won't always work - it's a mechanical part and can wear out - better to just replace the thing with a half decent one if you can - you can try a cheap one but don't expect it to last as long as an original.
mikal
Unread post by mikal »
how do I know what is best...…….
x 6960
There’s another one here that is complete with the loom
http://www.eurocarcare.net/switches-rel ... -loom.html
Or here
https://www.ebay.co.uk/itm/CITROEN-C2-C ... 1579819172
I gave you the part number in a previous post, so have a look around, but I really would avoid the really cheap ones.
mikal
Grassy ass
x 6960
Croeso
mikal
marc. We the feckin heck is that brake pedal linky thing. I took up the pass mat and reached under the "glovebox" and there is a plazzy horizontal piece held in by 2 hand rotating clips but under that...……….errrrrrrrrrrm lots of not a lot, especially the sort of brake arm shown. Is it further up and under??
admiral51
(Donor 2026)
x 394
Unread post by admiral51 »
mikal the brake pedal and arm etc will not be seen on the passenger side of a rhd, what you will see is the bar that runs from the drivers side to the passenger side.
remove the carpet trim that is under the glovebox that covers the gap between the floor carpet and glovebox, that should allow you to see the bar that runs from drivers side to passenger side and the brake switch should be visable as per the diagram posted.
On my C4 it is a similar set up and the switch is looking at you saying here i am :)
mikal
Cheers your lordship. LOL. On mine theres a plazzy trim where your toes would be if sitting down. Bit of a bugger turning and stretching your head. Might try a mirror. Cheers
Mike
x 6960
If you are changing the brake switch, be aware there are 2 types of switch, one that has to be manually set and one that automatically adjusts at fitting.
mikal
Oh cheers a feckin bunch, now you've got me all confused now and I havent touched a drop …………….yet
x 6960
I can't tell you why there are 2 types, but the part number is 453467.
One has to be manually set and the automatic one self adjusts once fitted. The part number above may also come with a modified loom - as can be seen from Euro Car Care:
I don't have the reason why the loom may be supplied and what this is for exactly - that may be a question for the dealer who may be able to answer it for you - as there could be a Technical Service Bulletin detailing the reason.
I thought it worth a mention before you embark on it yourself!
