306 HDi - No throttle response and stuck on 1300 rpm... Have I cooked my ECU?
- x 6956
Re: 306 HDi - No throttle response and stuck on 1300 rpm... Have I cooked my ECU?
If it helps I'll post up the complete wiring diagram for the MAF and TPS that should identify your earthing and termination.
- x 6956
Ok, here you go - this one is specific to your car with your options. Your 'MC**' are your earthing points. You can see the TPS and MAF bottom right as indicated on my last post which gives you the wiring functions for those parts. Note: Anything on the diagram with 'marching ants' around it is optional equipment that may not be fitted.
Look here on the Wiki for other electrical codes:
https://frenchcarforum.co.uk/wiki/Elect ... ring_Codes
picassodad
- x 15
Brill mark, do you have the legend that says whats what, like 1160 are the engine heater plugs ??
What exact info would you need for stuff like this for our 306 hdi estate please ?
- x 6956
Have a look at our Wiki here:
This will list the section with the most common component codes for wiring diagrams used by PSA vehicles.
I can only provide a diagram for a specific function (like injection or Alternator etc.) as it takes a little while to extract, format, upload and post.
dave_xsara
- (Donor 2021)
- x 10
picassodad wrote: 23 Nov 2018, 10:58 from time to time will reduce engine power when going around a right hand bend at speedo, but only very very occasionally.
https://www.honestjohn.co.uk/forum/post ... tm?t=36574
Probably too late for you, but found this elsewhere when searching about my own issues.Recently had a customer with this same problem, no throttle response for up to five seconds more evident after hard cornering, after exhaustive testing i sourced the fault to a miss adjusted brake pedal switch, customer had spent alot of money previously and had been told ecu fault, 'fly by wire' throttle housing, egr valve etc etc.
The brake switch cuts throttle action when depressed hence being miss adjusted a signal was being sent to the ecu telling it both the throttle and brake were being pressed together, with this information the ecu cuts throttle opening. It appears this is a common problem that is costing customers hundreds of pounds when a quick adjustment is all the is needed, even a new switch is only £8.00.
Hope this helps.
picassodad
- x 15
Thanks Dave xsara, was thinking along similar lines but the citroen ( xsara picasso 1.8 petrol ) is not with me at the moment as still welding up the pug, near finished near side then onto off side front of sill/jacking point area that is not as bad. Hope to get it finished and mot'd before mid july as we want to go on holiday in it!
If the doctor knew what i was getting up to he would go mad, had an "incident" last Jan and lucky to survive. Pills keep me alive these days.
Was gunna start at the fuel tank as no fuel pressure sensor and just a relief valve in the tank, no access hatch thru the floor so tank off, real creative technology eh!
Yeah ecu confused, remember the volvo v70 one, brake light issue ( brake lights on all the time ) causing domino effect with car refusing to start/run.
