Blaupunkt radio code
captainbugwash
Unread post by captainbugwash »
Just got a 97 Xantia 1.8lx and don't have the code for the radio. As far as I know radio is original and the serial number is BP2775V9715628. Is Anyone here able to work out code for me? Cheers
x 6963
Re: Blaupunkt radio code
I think your only hope is to speak to Citroen and see if the code is stored with your VIN on their database.
x 1436
Unread post by xantia_v6 »
I assume that you have checked that it has not been written somewhere in one of the handbooks?
If you have a record of the original supplying dealer, phone them first, as some kept their own records, so that they didn't need to pay Citroen for the data on a later occasion.
courierrelay
x 3
Unread post by courierrelay »
x 6963
Well spotted - I like the 'Free Postage' part for a code that is emailed! :rofl2: I don't suppose you can go wrong for a £!
captainbugwash
Thanks for link, have just tried it and waiting for email to come.
I didn't get any handbook with car so no code written anywhere. Luckily I did get the pin code for the car entry pad.😊
x 6963
^ Well that certainly helps^ :rofl2:
Good luck with the radio code.
x 1751
You can get the code instantly on-line here:
https://www.radio-code.co.uk/blaupunkt-radio-codes.html
using the 14-digit serial number.
Site allows choice of car or radio make.
Worked for me on some original Philips-Citroen kit.
x 6963
I’ve just tried that on a similar model on eBay and put the 14 digit number in beginning with BP, then you need to enter the 10 digit code on the unit.
Then after I did that it gave you the good news and says they have it, after you’ve coughed up £9!
For £15 you can buy the bloody stereo with code!
But probably cheaper than Citroen, although for £15 (even if they charged you), you could also get your key code and engine code for that price. :-D
captainbugwash
Two days now and no contact from £1 eBay seller.
What a surprise
x 1751
Try the one above (radio-code.co.uk)...
Ranko03
New User
Unread post by Ranko03 »
Hi, can anyone help me?, i need code for blaupunkt BP8140Y5510949
