GiveMeABreak wrote: ↑23 Nov 2018, 09:54 There is a way to test these - if you switch the ignition on and put the car in reverse, gently and lightly place your finger just above the sensor a few millimetres away from the sensor - you should feel a slight pulsing from each sensor - those that pulse should be working, those that aren't are likely to be faulty - but the surest way is a diagnostic, which you have done - so replace those 2 first.
OT
Hi again!
Can you help me to find the OEM number for window regulator for the passenger site? (Right side in my case)
Its broken as well wondering of buying the whole framme without motor, the wires were to complicated.
