Hi
Is it possible to get the immobilizer code for my car?
Citroen xafara
Getting my immobilizer code
- x 6948
Re: Getting my immobilizer code
If you mean Xsara? If you have one of the older models with a push button coded panel then you'll have to get the code from Citroen. You'll need your confidential code card and some proof of ownership and ID I suspect.
- x 1476
If it is a keypad immobiliser then the code is set by the user and not known by Citroen.
There are diagnostic boxes (not Lexia or Diagbox) which can read the code from the keypad, pump or ECU, but it is also possible to change the EEROM chip for one with a known code.
Lord zefron
It is just a key and NO key fob
It's a 58 plate
It's a 58 plate
- x 6948
Of course I was thinking one thing and saying another!xantia_v6 wrote: 25 Nov 2018, 17:20 If it is a keypad immobiliser then the code is set by the user and not known by Citroen.
- x 6948
What is your VIN, it won't be a Xsara on a 58 plate. nor will it have a keypad immobiliser!
OnlinePaul-R
- x 1944
Xsara Picasso I suspect...
- x 6948
None of the Xsara Picasso’s had immobiliser key pads either. If you don’t know what you have we’ll need a VIN
Lord zefron
Where will I find the vin?
Do I have to get the code from the main dealer?
- x 6948
Your VIN is in the lower outside corner of the left hand side of the windscreen in a little cut out. Either that or pop your registration here - I can get it form that.
