X7 electric tailgate
- x 6957
Re: X7 electric tailgate
Just a thought but check the wiring in this block here:
Lenny
- x 60
Is it possible to do away with the dreadful contraption?
I'd much prefer a normal manual tailgate.
Presumably if all this pointless gubbins was removed and replaced with a pair of wonderfully reliable (and not remotely annoying) gas struts then all sorts of fault codes would be thrown up?
- x 6957
That’s not really practical. There are masses of components integral to the tailgate. There’s nothing stopping one using it manually as it is, but I’m sure Steve just wants the functionality restored.
Trainman
- (Donor 2018)
- x 43
So, playing with the tailgate at the moment, I got it all stripped down, I’ve noticed that as the tailgate opens to about halfway, the light in the red boot switch goes out and the tailgate stops moving.
As soon as I put pressure on the tailgate to close it, just a fraction the switch lights up again. And you can use either the red switch or external switch to close it.
If I try to reset the parameters ( holding the button for 3 seconds) I get a long bleep and nothing else.
Steve
http://c6owners.org/index.php
- x 6957
There are only a couple of incidents where a single beep is mentioned anywhere - detailed with the procedures below. The initial configuration, once programmed, is retained even with removal of the battery - but I've included it here for reference.
This is the learning procedure - but it says memories can be cleared using Diagbox. As you've had a single beep, is it possible you have started the reconfiguration precess I wonder?
Learning
The motorised tailgate is delivered in "declutched" configuration: The tailgate can be opened or closed manually.
No operating of the motorised tailgate is possible until the initialisation has been performed correctly.
If a new control unit is fitted, initialise it.
N.B.: After replacing the control unit, clear the memories and re-initialise; Using the diagnostic equipment.
Programming procedure:
Re-initialisation of the motorised tailgate ECU has to be performed in the following instances:
Learning
- Lock the tailgate: With the striker plate in the "in" position, close the tailgate
- After 3 seconds,the position “tailgate closed” is initialised and the motorised tailgate ECU confirms with a short "beep"
- Press on the opening control and allow the motorised tailgate to open without hindering its movement
- The motorised tailgate goes to the maximum open position
- The position “tailgate open” is initialised and the motorised tailgate ECU confirms with a short "beep"
- The motorised tailgate system is initialised and can now be used normally
- The initialisation of the motorised tailgate was incorrectly carried out
- 1 cycle = 1 lighting (5s) + 1 extinction (3s)
- If replacing any mechanical components of the motorised tailgate (Tailgate struts - engine - Motorised tailgate)
- An action of maintenance on the motorised tailgate (an event that could modify the minimum and maximum opening angles of the motorised tailgate
- If the motorised tailgate is in the closed position after the deletion of the initialisation, the motorised tailgate ECU gives out a short "beep" as a signal that it is waiting for a new initialisation.
- Deletion of the initialisation is possible only in the following conditions
- No fault has been detected by the boot movement control unit
Trainman
- (Donor 2018)
- x 43
Didn't have chance today to carry on with the tailgate, Discovered it needed new discs and pads at the rear
I'll have a play tomorrow, after I finish sorting the brakes
Steve
- x 6957
It’s always the way!
Trainman
- (Donor 2018)
- x 43
Yeah, tell me about it.......
I did manage to get some screen shots from Lexia though
Steve
- x 6957
Interesting that you're using Lexia and not Diagbox or is that because you only haver Lexia installed?
Trainman
- (Donor 2018)
- x 43
No I have both, it was just the first one that came to had, plus the Diagbox laptop was in the house and Lexia was in the garage
Steve
DHallworth
- x 163
I know nothing about the Tourer but find this screenshot interesting...
In the first screenshot, the maximum opening angle is 93 degrees which would be wide open, why would the customised opening angle be only 50 degrees? That means the tailgate would stop half way open does it not?
David.
'98 Xantia Activa V6
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
Trainman
- (Donor 2018)
- x 43
My plan is to get Diagbox on it tomorrow after sorting the brakes, it will be interesting to see if there is a comparison and if there are any adjustments I can make to it
Steve
DHallworth
- x 163
I wonder if there's a feature where you can program it by double pressing the opening button or similar to set the opening angle.
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 6957
It's because the tailgate opening angle can be customised - but needs to be at least an angle of 50° and yes, to programme it you allow it open to the desired angle, then pause it by stopping it with the button or manually and then holding either the tailgate or the outer button in for 3 seconds, then it is programmed to your requirement - as long as at least 50°DHallworth wrote: 25 Nov 2018, 22:05
David.
Trainman
- (Donor 2018)
- x 43
Now I can understand that, but what I can't figure out is why the button is losing power after it reaches 33% open
Steve
